WAB 2.7 Public Notification Widget
1104
7
02-28-2018 03:47 PM
MatthewPugh1
Although it is great to see this Public Notification widget in WAB 2.7, I was wondering why it is when I use the selection tools (point, straight line, polyline, polygon, freehand polygon) to select a group of parcels, the search distance is applied to the geometry of the search tools instead of the geometry of the selected parcels. In WAB 2.8, can there be an option to allow the search distance to be applied to the outline of the selected parcels instead of the search tool geometry?
Thank you.
ChrisBuscaglia
Absolutely, this will be an option with the next release.
Currently, the geometry has to be a result from the search to use it.
Chris Buscaglia
Local Government Solutions Team
ChrisBuscaglia
This enhancement has been officially released and is available.
If you would like use interactive selection tools to add or remove selected features from the map, check the box for Use selection drawing tools.
Public Notification | ArcGIS for Local Government
Please let technical support know if you run into any issues.
Chris
CCWeedcontrol
Occasional Contributor III
So how do you download it to install in WAB 2.7?
AllisonMuise1
This update will be included with WAB developer edition 2.8 which should be released in the next week or two.
CCWeedcontrol
oh ok, awesome!
BPriyaK
New Contributor III
Hello Chris,
I have downloaded the 2.9 version of the web app builder and the selection by drawing tools doesn't seem to work any idea why and how to fix this issue
Thank you
ChrisBuscaglia
BPriya K‌ I'm not sure exactly, can you share some screenshots of your configuration panel?
Chris
