My form contains a repeat with a select_one question to identify the slope. The choice list is as follows:
slope | <20% | Mostly Flat <20% |
slope | 20-50% | Sloped 20-50 % |
slope | > 20% | Steep >50% |
No matter what selection I've made, the database takes the value of the label, so I've tried making the select_one question null and created a another field that takes (using a calculation) the value selected in the select_one question. This works indeed, with the caveat that all the answers for this question is automatically changed for all the records in the repeat to the last value selected.
I don't think this makes sense, since every record withing the repeat should behave independently of the previous one.
Please advise if it might be due to some type of bug.
Hi Javier,
Can you please share a copy of your survey xlsx form, so I can take a closer look.
Regards,
Phil.
Good afternoon Phil.
Sorry about the delay. I’ve tried something else, and no need to add a calculated field or similar, since everything works as expected.
FYI, I believe there is an issue when creating a Survey from an existing one and the folder and associated files that created. I went ahead and deleted any file that didn’t relate to the Survey and that did the trick.
Check the screen capture below to illustrated this:
Let me know if you have any question.
Thanks for getting back with me.
Javier
