My research includes a lot of hiking for surveying. I have a fitbit which uses GPS to map my hikes. I can export the data to TCX file. How do import this and use it with ArcGIS Pro or Desktop, or is there a way I can convert it into a compatible format for ArcGIS?
According to Training Center XML - Wikipedia it's a particular flavor of xml, and according to that article it's similar to the gpx flavor of xml that Garmin gps units spit out. I'm pretty sure ArcGIS can read a gpx file, so you may want to find a gpx file and compare it to your tcx file and then see if there is a conversion routine available to do so. See this too: TCX Converter - The multiconverter tool
edited to add: GPX to Features tool : GPX To Features—Help | ArcGIS Desktop
Here is what your tcx file looks like in xml notepad:
I used Garmin Basecamp to import my TCX files and export them as GPX - very easy to do!
I was able to open the TCX file in excel, save as a csv and add to arcpro. My file includes fields for the lat/longs.
I just used the AllTrails file converter and was able to spit out the .tcx as a .kml. Just threw it into Pro and it worked like a charm.
