AnsweredAssumed Answered
Error Pasting to Clipboard with Python in ArcMap 10.6
Question asked by P_Jutson on Feb 23, 2018
Latest reply on Feb 26, 2018 by P_Jutson
I have been testing an existing Python Add-In written for ArcMap 10.2 that throws an error in ArcMap 10.6. The error was 'module' object has no attribute 'argv'.  After checking the web it looked like code I used to past to the clipboard with Tkinker was the problem. To test I copied the following code from the Add-In and pasted into the Python Window and an error was generated on usage.
>>> import Tkinter
>>> def toClipboard(txt):
...     clip = Tkinter.Tk()
...     clip.withdraw()
...     clip.clipboard_clear()
...     clip.clipboard_append(txt)
...     clip.destroy()
>>> toClipboard("Hello")
Runtime error
  File "<string>", line 1, in <module>
  File "<string>", line 2, in toClipboard
  File "C:\Python27\ArcGIS10.6\Lib\lib-tk\Tkinter.py", line 1814, in __init__
    baseName = os.path.basename(sys.argv[0])
AttributeError: 'module' object has no attribute 'argv'
In ArcMap 10.2 this code runs without a problem. The wisdom of the web suggests that a similar problem happened in ArcMap 10.1 and could be to do with the way sys has been altered for ArcGIS.
Have I found a bug?
Outcomes
