AnsweredAssumed Answered
Add attachment larger than 10 MBs
Question asked by jskinner-esristaff Employee on Feb 22, 2018
Has anyone had success uploading an attachment larger than 10 MBs to an ArcGIS Online hosted feature service?  I know that this is not possible via a web browser.  I'm trying to upload a video (.mp4) around 50 MBs.  I broke the video into smaller chunks so that each .mp4 is less than 10 MBs.  I tried the following python script using the uploadPart and addAttachment REST functions to achieve this, but keep receiving an error in the addPart function:
{u'error': {u'message': u'', u'code': 400, u'details': [u'Unable to upload item.']}}
Below is my script.  Any help is appreciated.
import requests, json, os
# Disable warnings
requests.packages.urllib3.disable_warnings()
# Variables
username = "jskinner_Tred"
password = "****"
id = 1252
TempDir = r"D:\Projects\Treddyfrin\Temp"
# Generate AGOL Token
tokenURL = 'https://www.arcgis.com/sharing/rest/generateToken'
params = {'f': 'pjson', 'username': username, 'password': password, 'referer': 'http://www.arcgis.com', 'expiration': 21600}
r = requests.post(tokenURL, data = params, verify=False)
response = json.loads(r.content)
token = response['token']
# Register Item
print("Registering Item")
uploadURL = 'https://services2.arcgis.com/o9a0D2ZwwG8CDFVQ/arcgis/rest/services/Sewers/FeatureServer/uploads/register'
params = {'f': 'pjson', 'token': token, 'itemName': 'attachment1252', 'description': 'Attachment for feature 1252'}
r = requests.post(uploadURL, data = params, verify=False)
itemID = str(response['item']['itemID'])
# Upload Parts of video to Registered Item
def addPart(itemID, token, filename, num):
    '''Add part of the input video using a post request through the request module'''
    print("Adding parts of video")
    addpartURL = 'https://services2.arcgis.com/o9a0D2ZwwG8CDFVQ/arcgis/rest/services/Sewers/FeatureServer/uploads/' + itemID + '/uploadPart'
    params = {'token':token, 'f':'pjson', 'partNumber': str(num)}
    image = {'partFile': (os.path.basename(filename), open(filename, 'rb'), 'video/mp4')}
    response = requests.post(addpartURL, data = params, files = image)
    print(json.loads(response.text))
# Walk through temp directory to get each video part
for a, b, c in os.walk(TempDir):
    for name in c:
        print(name)
        index = int(name.replace('output', '').replace('.mp4', ''))
        addPart(itemID, token, os.path.join(TempDir,name), index)
# Commit upload
print("Commiting upload")
commitURL = 'https://services2.arcgis.com/o9a0D2ZwwG8CDFVQ/arcgis/rest/services/Sewers/FeatureServer/uploads/' + itemID + '/commit'
params = {'f': 'pjson', 'token': token}
response = requests.post(commitURL, data = params)
# Add attachment to feature
print("Adding attachment to feature")
fsURL = 'https://services2.arcgis.com/o9a0D2ZwwG8CDFVQ/ArcGIS/rest/services/Sewers/FeatureServer/0/' + str(id) + '/addAttachment'
params = {'f': 'pjson', 'token': token, 'uploadId': itemID}
response = requests.post(fsURL, data = params)
print(response.content)
Outcomes
