AnsweredAssumed Answered
ArcGIS API for Python installation with CONDA does not found packages
Question asked by xtian79 on Feb 22, 2018
Latest reply on Feb 22, 2018 by xtian79
Hello fellows,
I want to install the ArcGIS API for Python , I proceed as state at https://developers.arcgis.com/python/guide/install-and-set-up/#Install-using-Anaconda-for-Python-Distribution
but get  the following error:
conda install -c esri arcgis
Solving environment: failed
UnsatisfiableError: The following specifications were found to be in conflict:
  - arcgis
  - xlsxwriter
Use "conda info <package>" to see the dependencies for each package.
then I tried the following command:
conda install arcgis
PackagesNotFoundError: The following packages are not available from current channels:
  - arcgis
Current channels:
  - https://repo.continuum.io/pkgs/main/win-64
  - https://repo.continuum.io/pkgs/main/noarch
  - https://repo.continuum.io/pkgs/free/win-64
  - https://repo.continuum.io/pkgs/free/noarch
  - https://repo.continuum.io/pkgs/r/win-64
  - https://repo.continuum.io/pkgs/r/noarch
  - https://repo.continuum.io/pkgs/pro/win-64
  - https://repo.continuum.io/pkgs/pro/noarch
  - https://repo.continuum.io/pkgs/msys2/win-64
  - https://repo.continuum.io/pkgs/msys2/noarch
I check for the info of conda:
conda info
     active environment : base
    active env location : C:\Users\CGLondono\AppData\Local\Continuum\anaconda2
            shell level : 1
       user config file : C:\Users\CGLondono\.condarc
 populated config files :
          conda version : 4.4.10
    conda-build version : 3.4.1
         python version : 2.7.14.final.0
       base environment : C:\Users\CGLondono\AppData\Local\Continuum\anaconda2  (writable)
           channel URLs : https://repo.continuum.io/pkgs/main/win-64
          package cache : C:\Users\CGLondono\AppData\Local\Continuum\anaconda2\pkgs
                          C:\Users\CGLondono\AppData\Local\conda\conda\pkgs
       envs directories : C:\Users\CGLondono\AppData\Local\Continuum\anaconda2\envs
                          C:\Users\CGLondono\AppData\Local\conda\conda\envs
                          C:\Users\CGLondono\.conda\envs
               platform : win-64
             user-agent : conda/4.4.10 requests/2.18.4 CPython/2.7.14 Windows/10 Windows/10.0.16299
          administrator : False
             netrc file : None
           offline mode : False
What I am missing???
Outcomes
