Survey123 Report Templates: Conditional Field Appearance in Report
2145
5
02-21-2018 07:25 AM
CatherineMurphy
I have some surveys that are a bit lengthy and my end users would prefer them to be more concise. Most of the questions are yes/no/n/a, and depending on the response, will allow the user to add notes. In the report that is generated, I would like to mirror the conditional notes field rather than generating reports with all but ~1-3 notes fields appearing empty. I know it's still a beta feature, but is this possible? And if so, how do I go about doing this?
JamesTedrick
Esri Esteemed Contributor
Hi Catherine,
Currently, conditional show/hide is not available in the print templates.  It is a feature that we are working on for a future release.
CatherineMurphy
Hey James,
Thanks for the speedy response. I'm glad to hear you guys are hard at work getting it ready for a future release. I and my company will definitely get a lot of use out of it. Thanks again and have a great rest of the week!
DudleyHartel
I used this Survey123 report template (a Word doc) successfully to conditionally print attributes:
Tree Species:
${TreeGenusSpecies}
DBH:
${TreeDBH}
Tree Height:
${TreeHeight}
Failure:
${TreeFailureType}      [Note: this is a single-select that returns RF (Root Failure), TF (Trunk Failure), BF (Branch Failure); after which the form user  is prompted for attributes specific to that type of failure]
${if TreeFailureType == “Root Failure”}
Root Failure Type:
${RootFailureType}
${if TreeFailureType == “Trunk Failure”}
Trunk Failure Height:
${TrunkFailureHeight}
Trunk Failure Diameter:
${TrunkFailureDiameter}
${if TreeFailureType == “Branch Failure”}
Branch Diameter:
${BranchBreakDiameter}
Branch Length:
${BranchLength}
These if statements against form attributes seemed to work.  Isn't this what you are referring to?
TNGStewardship
New Contributor III
Thanks Dudley - I was having the same problem/question as Catherine. This solved it!
The fields only show up if there is data in them!
Emily
gls
@JamesTedrick Is conditional show/hide available in report templates now? I have a lengthy survey and would like the report to only show questions that have data in them.
