Please help Grouping analysis
3238
02-20-2018 11:52 AM
KathyMulcahy
pro.arcgis.com
Legacy: The algorithm behind the Grouping Analysis tool has been enhanced and new functionality has been added to these methods at ArcGIS Pro 2.1.
arcpy.stats.GroupingAnalysis("Serious Violent Crimes", "CCN", r"D:\Kathy\Desktop\ProT\EsriPress\bookdata\GIST1Pro\Chapter9\Tutorials\Chapter9.gdb\SeriousViolentCrimes_Groupin", 5, "Hierarchy;ArrGender;ArrRace;ARRAgeStnd", "NO_SPATIAL_CONSTRAINT", "EUCLIDEAN", None, None, "GET_SEEDS_FROM_FIELD", "Seed", r"D:\Kathy\Desktop\ProT\EsriPress\bookdata\GIST1Pro\Chapter9\Tutorials\clustereport.pdf", "DO_NOT_EVALUATE")
  File "<string>", line 1, in <module>
NameError: name 'arcpy' is not defined
import arcpy
  File "d:\arcgis\pro\Resources\arcpy\arcpy\stats.py", line 772, in GroupingAnalysis
    raise e
  File "d:\arcgis\pro\Resources\arcpy\arcpy\stats.py", line 769, in GroupingAnalysis
    retval = convertArcObjectToPythonObject(gp.GroupingAnalysis_stats(*gp_fixargs((Input_Features, Unique_ID_Field, Output_Feature_Class, Number_of_Groups, Analysis_Fields, Spatial_Constraints, Distance_Method, Number_of_Neighbors, Weights_Matrix_File, Initialization_Method, Initialization_Field, Output_Report_File, Evaluate_Optimal_Number_of_Groups), True)))
  File "d:\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 506, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: Traceback (most recent call last):
  File "d:\arcgis\pro\Resources\ArcToolbox\Scripts\Partition.py", line 30, in <module>
    import SSUtilities as UTILS
  File "d:\arcgis\pro\Resources\ArcToolbox\Scripts\SSUtilities.py", line 25, in <module>
    import SSDataObject as SSDO
  File "d:\arcgis\pro\Resources\ArcToolbox\Scripts\SSDataObject.py", line 27, in <module>
    import WeightsUtilities as WU
  File "d:\arcgis\pro\Resources\ArcToolbox\Scripts\WeightsUtilities.py", line 22, in <module>
    import SSPanelObject as SSPO
  File "d:\arcgis\pro\Resources\ArcToolbox\Scripts\SSPanelObject.py", line 18, in <module>
    import pandas as PANDAS
  File "D:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\__init__.py", line 42, in <module>
    from pandas.core.api import *
  File "D:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\api.py", line 10, in <module>
    from pandas.core.groupby import Grouper
  File "D:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\groupby.py", line 49, in <module>
    from pandas.core.frame import DataFrame
  File "D:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\frame.py", line 67, in <module>
    from pandas.core.generic import NDFrame, _shared_docs
  File "D:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\pandas\core\generic.py", line 41, in <module>
    import pandas.core.indexing as indexing
AttributeError: module 'pandas' has no attribute 'core'
Failed to execute (GroupingAnalysis).
import arcpy
GroupingAnalysis_stats("Serious Violent Crimes", "CCN", r"D:\Kathy\Desktop\ProT\EsriPress\bookdata\GIST1Pro\Chapter9\Tutorials\Chapter9.gdb\SeriousViolentCrimes_Groupin", 5, "Hierarchy;ArrGender;ArrRace;ARRAgeStnd", "NO_SPATIAL_CONSTRAINT", "EUCLIDEAN", None, None, "GET_SEEDS_FROM_FIELD", "Seed", r"D:\Kathy\Desktop\ProT\EsriPress\bookdata\GIST1Pro\Chapter9\Tutorials\clustereport.pdf", "DO_NOT_EVALUATE")
  File "<string>", line 2, in <module>
NameError: name 'GroupingAnalysis_stats' is not defined
import arcpy
    raise e
JustinConnerWR
Occasional Contributor II
Kory Kramer‌ I'm also getting this pandas error trying to run the TableToExcel_conversion tool from the Python window, but I think this would be classified more appropriately under ArcGIS Pro or Analysis
KoryKramer
Esri Community Moderator
Python
JENNYLIII
Hello @KathyMulcahy ,
I've try to run grouping analysis and also require the output report. Unfortunately, i got the same problem with you. And from other Community, there is someone sharing that "Traceback error" can fix by rename the report without typing "space". Although trying through, it's still can't work. So, If it is convenient, can you share how to figure out this problem?
