How to show a callout, only on clicking on a markersymbol ?
1488
02-19-2018 03:28 AM
PhaniBhushankolla
Is there any delegate method to show a callout, by clicking on a marker symbol.
Similar to didTapAtScreenPoint delegate method, which displays a callout wherever the user clicks on the map.
MuruganandhamKuppan1
New Contributor III
There is no separate delegate. Here is some sample,
/*  Create a graphics with symbol**/
  AGSPoint * graphicPoint = [AGSPoint pointWithX:-9547261.91529309 y:4615891.15535562 spatialReference:[AGSSpatialReference webMercator]];
    NSMutableDictionary * graphicAttributes = [NSMutableDictionary dictionaryWithObjectsAndKeys:
                         @"Frazier Museum", @"name",
                         @"829 West Main Street, Louisville, KY 40202", @"address",nil];
   AGSPictureMarkerSymbol * graphicSymbol = [AGSPictureMarkerSymbol pictureMarkerSymbolWithImage:[UIImage imageNamed:@"Museum.png"]];
    AGSGraphic * graphic = [AGSGraphic graphicWithGeometry:graphicPoint symbol:graphicSymbol attributes:graphicAttributes ];
   /*** Add the graphics to AGSGraphicOverlay and add AGSGraphicOverlay as AGSMapview's subview ***/
    [self.graphicsOverlay.graphics addObject:graphic];
/** use AGSGeoViewTouchDelegate to detect tap in mapview*/
- (void)geoView:(AGSGeoView *)geoView didTapAtScreenPoint:(CGPoint)screenPoint mapPoint:(AGSPoint *)mapPoint {
    NSLog(@"didTapAtScreenPoint %@ %@",NSStringFromCGPoint(screenPoint), mapPoint);
    __weak __typeof(self) weakSelf = self;
    [self.mapView identifyGraphicsOverlay:self.graphicsOverlay screenPoint:screenPoint tolerance:12 returnPopupsOnly:NO maximumResults:1 completion:^(AGSIdentifyGraphicsOverlayResult * _Nonnull identifyResult) {
                AGSGraphic *graphic = identifyResult.graphics.firstObject;
                if (graphic){
                        // show callout for identified graphic
                        [weakSelf showCalloutForGraphic:graphic tapLocation:mapPoint];
                else{
                        // nothing tapped - dismiss callout
                        [weakSelf.mapView.callout dismiss];
-(void)showCalloutForGraphic: (AGSGraphic*)graphic tapLocation:(AGSPoint*)tapLocation {
    self.mapView.callout.title = graphic.attributes[@"name"];
    self.mapView.callout.detail = graphic.attributes[@"address"];
    [self.mapView.callout setAccessoryButtonHidden :false];
    [self.mapView.callout showCalloutForGraphic:graphic tapLocation:tapLocation animated:YES];
/** add below delegate methods to show the popups - AGSCalloutDelegate */
-(BOOL)callout:(AGSCallout*)callout willShowAtMapPoint:(AGSPoint *)mapPoint{
    return TRUE;
-(BOOL)callout:(AGSCallout*)callout willShowForLocationDisplay:(AGSLocationDisplay*)locationDisplay {
    return TRUE;
- (void)didTapAccessoryButtonForCallout:(AGSCallout *)callout {
    if (![callout.representedObject isKindOfClass:[AGSGraphic class]]){
        // we are expecting a graphic in this sample
        return;
    NSLog(@"%@",callout.title);
New Contributor III
                if (graphic){
                else{
    return TRUE;
    return TRUE;
        return;
PhaniBhushankolla
Worked perfectly, thanks a lot.
AsifIsmail
New Contributor III
Can u pls help me with swift.
 I have set of marker from feature layer,tapping on it should bring up the call-out.
Please do help.
