ArcPAD 10 how to change the Coordinate from WGS to UTM
1136
02-17-2018 01:24 AM
DIALLOAbdoulaye
Hello EveryOne, i am currently with ArcPAD  10. with trimble juno 3D.  I noticed that by default ArcPAD shows the coordinate with WGS system . In my case i want to use UTM (ZONE 28).
I went to the GPS preference > Protocole and set the datum to ConakryZone28 (My datum area)  instead of WGS84. the GPS  keep showing the coordinate with WGS System.
I also start new project with Arcgis Desktop , i ensured that the MXD is in UTM then with ArcPAD Manager i export the project  to my Mobile device ( The GPS keep showing the coordinate with WGS System ).
Does anyone know how to change de coordinate from WGS to UTM ?
Any Help will be higly appreciated.
MelitaKennedy
Esri Notable Contributor
According to this knowledge base article, it looks like it's not enough that the map document is using Conakry UTM 28N. The actual data layers must also be using Conakry UTM 28N. If they aren't, use the Project Tool to make copies of the data that are in Conakry UTM zone 28N.
StephenQuan1
Diallo,
Please do not change the GPS Protocol's projection. I will explain why, shortly, but, the GPS protocol should be in D_WGS_1984, and, only in special circumstances, should you change this.
Since you mentioned you are using ArcPad Data Manager to check out your data from ArcGIS Desktop to ArcPad, ArcPad should be loading your data in the correct projection. You need to check that your map projection of your map in ArcGIS Desktop is correct. Optionally, you need to ensure that the data sources in your map are also in the correct projection - it's optional, because checkout will reproject on check out and will reproject on check in.
ArcPad when dealing with projection:
 1. When there's no data loaded, by default, it's in WGS84
 2. If there is a projection defined in your ArcPad Map Project (.apm), it will use it, otherwise
 3. When you load data, projection will adapt to the *FIRST* dataset loaded, so, you need to add a feature class, like a Shapefile or AXF of data in your projection
 4. When you load more data, the projection will only adapt to secondary datasets, if the primary datasets were deemed reprojectable, e.g. redlining layers and ArcGIS Online basemaps are examples of reprojectable layers, otherwise, the projection will lock onto the primary dataset and attempt to reproject secondary datasets to it
ArcPad has a projection library but it only invokes it in the following scenarios:
 - reprojecting ArcGIS Online basemaps to your map
 - reprojecting GPS coordinates to your map
 - reprojecting redlining layer to your map
The GPS Datum must be left as D_WGS_1984 so that the reprojection library can reproject GPS coordinates correctly onto your map. Some special GPS hardware allow you to change the GPS datum, and, only in that circumstances, should you change the GPS Datum in ArcPad to match your GPS hardware. i.e. this setting has nothing to do with your desired map's projection.
You mentioned that you're having an issue with ArcPad on your Trimble Juno 3D. Can you elaborate more details to the circumstances of your issue and what you've attempted to do to fix it? i.e. do you try loading your data on ArcPad on Windows? Did it work? Did you see the same problem? i.e. I want to know if your problem is specific to your Trimble Juno, or, if your problem is a general ArcPad issue.
Stephen
