WHERE CLAUSE CALCULATIONS
488
02-14-2018 08:05 AM
JAVIERVARA_SANZ
Occasional Contributor II
I have a repeat that tracks time and temperature, among other variables. The calculation field will allow me to retrieve the maximum and minimum temperature, but I also would like to get the Time for these two values. I don't think an if statement will do the trick, so looking for an option to use something similar to a where clause.
Please advise.
Thanks.
JamesTedrick
Esri Esteemed Contributor
Hi Javier,
Currently, you can't do this in the form itself; this would need to be a post-processing step after form submission.
JAVIERVARA_SANZ
Good morning James.
Sorry for the delay.
I understand the limitations. Has Esri ever considered developing any type of functionality to allow the configuration of triggers? I’m aware this quite an ambitious request, but it will definitely add a lot of value.
As always, thanks for your support and responsiveness.
JamesTedrick
Hi Javier,
We are considering some methods of post-submission action (you can see it in the Survey123 Early Adopter Community and ArcGIS Online Hosted Feature Service Notification on new record/feature added).
