Hi Everyone,
So, I've been hoping that ESRI would integrate a dot density symbology option into ArcGIS Pro, and there have been some topics on dot density for both Pro and AGOL for awhile.
I had been of the mind that this didn't exist yet because it is not showing up as an option under symbology in ArcGIS Pro. Then I saw this webpage on esri.com and wondered if I was missing something?
Dot density—ArcGIS Pro | ArcGIS Desktop
Any idea if this is possible or not? I don't see the symbology option when I follow the directions at this link.
Thanks so much!
Solved! Go to Solution.
I saw the update email for Pro 2.1, and the email pointed to this link--which didn't mention dot density symbology:
What’s in the January 2018 ArcGIS Release | ArcGIS Blog
It definitely shows up on the What's new in ArcGIS Pro 2.1 link you posted though!
It would be amazing if it really is part of the 2.1 update! (downloading...). Thanks for the info!
Confirmed! I downloaded the latest update and Dot Density is now a symbology type!!
This made my day!! Thanks for listening ESRI!
To anyone who has already installed 2.1 and is still confused and not seeing this option, just as a quick heads up:
Per Symbolize feature layers—ArcGIS Pro | ArcGIS Desktop ,
"Only available for polygon features."
In case anyone is trying to symbolize points, it's meant for polygons. I know the name can be a bit confusing.
Give us a call if you have any further issues!
Best regards,
Rachel
Esri Support Services
