ArcGIS GeoEvent Server Components
475
02-13-2018 07:12 AM
Okeke_Onyedikachi1
New Contributor III
Dear all,
Please can someone assist with all and detited Hardware,software,network and service components needed to deploy GeoEvent server in defence precisely  Airforce.
you can just itemise or list them out here.
Thank you.
DanielCota1
Hi OKEKE ONYEDIKACHI JOSHUA
Here are some documentation links you may find useful in deploying a GeoEvent Server environment:
System requirements—ArcGIS GeoEvent Server (Windows) Installation Guide (10.6) | ArcGIS Enterprise
Installing GeoEvent Server—ArcGIS GeoEvent Server (Windows) Installation Guide (10.6) | ArcGIS Enter...
These are the bare bones of what is required to successfully implement GeoEvent Server. If you follow all of these specifications, you should have no issue.
However, if you are looking for something a little more customized to your environment, as you noted with regards to Defense, you may need to contact Esri to see if you can inquire about a Professional Services engagement. We understand that deployment scenarios will vary and this will likely be your best option if you need advice specific to your environment.
Hope this helps.
Okeke_Onyedikachi1
New Contributor III
Thanks for this, yes I will need something more customised to the environment here..
