How do I convert a field value to NULL?
27625
18
02-12-2018 12:28 PM
StewartGalloway
New Contributor III
How do I convert a field value to NULL?  I tried Calculate. Not sure how to use Python = "none" but I could not get it to work.
Thanks.
Stew
JamesMacKay3
Try "None" without surrounding quotes (it's also case-sensitive).
AbdullahAnter
Occasional Contributor III
Do you check if the field is nullable or not?
JamesMacKay3
DanPatterson_Retired
In summary, make sure the field is nullable and you use the python parser when typing ... None ....
since None is a python object for sure... not sure about other parsers.
JoeBorgione
Null in VB.
don't encourage vb Joe
TedKowal
😮   But it is so readable and understandable unlike Python
Lake_Worth_BeachAdmin
Python is very user friendly
TedKowal
Just like Perl!  Even though I respectfully disagree!  I find it to be an awful language...but who am I to say... the masses embraced it so in order to progress I have to deal with it!
Come on Ted... you are getting behind... more on the horizon   for instance...  https://julialang.org/
