Data Driven Pages and the arcpy DA Module
1203
02-06-2018 02:56 PM
OlyPowers
New Contributor III
I've written a script that is going to run Data Driven Pages nightly after checking to see if edits have been made to a feature class. In my code below the first function does not work, and I cannot for the life of me figure out why. It stops functioning at line 22 while I'm trying to set the current page for the DDP. After some serious experimentation, the second function does exactly what it's supposed to do. At this point the problem is solved, however I would like to know why the first function doesn't work. So far the only thing I've been able to come up with is that DDP does not play nice with search cursors.
import arcpy
from arcpy import env
env.overwriteOutput = True
import arcpy.da
from pytz import timezone
from datetime import datetime, timedelta
workspacePath = r"\\pathway\files\GIS\Projects\SDE_CONNECTION_FILES\GIS_USER_DC_GISDS_GIS.sde"
projectFC = workspacePath + "\GIS.DBO.ENG_PW_CONSTRUCTION_PROJECTS"
nowUTC = datetime.now(timezone('UTC'))
now = nowUTC.replace(tzinfo=None)
yesterdaysDate = now - timedelta(days=1)
mxd = arcpy.mapping.MapDocument(r"Q:\GIS\Projects\Engineering\Project_ID_Maps\ENG_Projects.mxd")
ddp = mxd.dataDrivenPages
indexLayer = ddp.indexLayer
def lastEditedOriginalCode():
    with arcpy.da.SearchCursor(projectFC, ['ID_KEY', 'last_edited_date'])as searchCursor:
        for row in searchCursor:
            pageID = ddp.getPageIDFromName(row[0])
            ddp.currentPageID = pageID
            if row[1] > yesterdaysDate:
                arcpy.mapping.ExportToJPEG(mxd, r"\\INTRANET\GISmap\\" + str(row[0]) + ".jpg", resolution=300)
                print "Exported New Map"
            else:
                print "No New Map Needed"
def lastEditedWorking():
                arcpy.SelectLayerByAttribute_management(indexLayer, "NEW_SELECTION", ' "ID_KEY" = \'{0}\''.format(row[0]))
                for each in ddp.selectedPages:
                    ddp.currentPageID = each
            else:
lastEditedWorking()
Here's the Error I get when I run the OriginalCode
  File "Q:/GIS/Projects/Engineering/Project_ID_Maps/Eng_Proj_Script/EngProjMap.py", line 45, in <module>
  File "Q:/GIS/Projects/Engineering/Project_ID_Maps/Eng_Proj_Script/EngProjMap.py", line 24, in lastEditedOriginalCode
  File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\utils.py", line 182, in fn_
    return fn(*args, **kw)
  File "C:\Program Files (x86)\ArcGIS\Desktop10.4\ArcPy\arcpy\_mapping.py", line 340, in getPageIDFromName
    return convertArcObjectToPythonObject(self._arc_object.getPageIDFromName(*gp_fixargs((page_name,), True)))
ValueError: 478
Value Error is the actual value of the page that's supposed to be the current page.
I just want to know why my first attempt didn't work. Any feedback would be welcome.
DanPatterson_Retired
if that is the page number why not try its number since this suggests a key,which could be text (string).  I would throw a print statement in to see what it is actually returning and whether it exists
getPageIDFromName (page_name)
Returns a Data Driven Pages index value based on the name of the page
There is more information here http://desktop.arcgis.com/en/arcmap/latest/analyze/arcpy-mapping/datadrivenpages-class.htm
where they use the pagenumber from the number of pages (see the code sample)
mxd.dataDrivenPages.currentPageID = pageNum
OlyPowers
New Contributor III
Well, I'm getting the same error when I try to print the value of pageID.
Which is interesting.
            print pageID
            # ddp.currentPageID = pageID
            # if row[1] > yesterdaysDate:
            #     arcpy.mapping.ExportToJPEG(mxd, r"Q:\GIS\Projects\Engineering\Project_ID_Maps\ExportTests\\" + str(row[0]) + ".jpg", resolution=300)
            #     print "Exported New Map"
            # else:
            #     print "No New Map Needed"
ValueError: 478
Let me dig into this some more
Hmmm. 10.4, you might want to check my Issues Addressed links in the Py Links to see if it is version specific problem
ScoutStanley
New Contributor III
Hi, is there any update on how this got corrected? Using Python 3 , so ms.getPageNumberFromName() is what I am using, but this exact issue is popping up.
