Leader control
385
02-06-2018 01:36 PM
BobChristensen
Hi, I am hoping for some help on how to control where a leader starts for a text balloon callout. In this case, I am just labeling by inserting a text rectangle then right clicking on the text rectangle and selecting add leader. I see the leader is created but I am unable to move the vertex to the correct anchor point. How do I accurately establish the anchor point for the leader?
b
WendyHarrison
Hi Bob,
Are you looking to edit the anchor point where the leader points to the feature being annotated?  Or the anchor point where the leader attaches back to the text?
thanks
Wendy
BobChristensen
Where it connects to the feature. Thanks!
WendyHarrison
Hi Bob,
Once you add the leader you will have a green anchor point for the annotation feature.  Hover the edit annotation tool over it and then click to move to the appropriate location.  Below is an image showing the workflow.  Please let me know if you're doing something different and this workflow doesn't work for you.
thanks
Wendy
BobChristensen
Thanks Wendy, and sorry for the slow reply. I have been working on other things long enough I do not know what I was doing wrong before. I believe I followed the same steps before but each time I dragged and dropped the leader anchor point it just snapped back to the position it snapped to when I created it. I had deleted the previous callout and did not experience the same issue when I started from scratch after your post so as far as I can tell it is working well. I will pipe back in here if this issue comes up again for me.
b
