Remove extra spaces with Attribute Assistant
540
02-05-2018 02:30 PM
JoeBorgione
Lets say a guy has an attribute value that gets entered like this: myfield = "TOO  MANY SPACES" where there are two spaces between TOO & MANY.
Using the attribute assistant, how would that guy drop the double space and replace it with just one?
JoeBorgione
moments later it came to me.  In the dynamic values table, enter a new record accordingly for Table Name, Field Name, Value Method will equal EXPRESSION and Value Info will use the replace function like this:
(Replace[myfield],"  "," "))
If you want to look for additional spaces like three or four, just add a line for each and change the Replace() to reflect the number of spaces
DanPatterson_Retired
does attribute assistant use python? (don't have it)  If so check the other thread that you were working on
JoeBorgione
No or I would'n have hit the VBs wall...  It's working now; extra spaces were giving me heartburn.
