2 Qs - 1 Modify Submit Button, & 2 Auto-Submit Survey
1317
02-06-2018 12:16 PM
EarlDeCastro1
Hi all,  I am in the process of creating a few surveys and have two questions that I cannot find answers to online.  Assistance is greatly appreciated.
1)  Is there a way to modify the appearance of the submit button (size, color, text, etc...)?  The small checkbox button works for most people, but some would prefer something a little different.
2)  Is there a way to auto-submit a survey after a barcode has been scanned?  I will have a lot of items being scanned in a short time-span, and would love to be able to save time and work by not having to press submit after every scan.
Thank you for your time and input!
JamesTedrick
Esri Esteemed Contributor
Hi Earl,
1) Currently, the buttons in the mobile application cannot be restyled by configuration
2) There isn't a way to specify for sending after a barcode scan through survey configuration
That being said, both of these could be relatively easily accomplished by customizing the Survey123 application, which is available as an open source template via AppStudio.
MattEimers1
Can you please point me in the right way to find the open source?
IsmaelChivite
Esri Notable Contributor
The source code of Survey123 is included with AppStudio for ArcGIS.
Have a look at https://community.esri.com/groups/survey123/blog/2018/04/29/customizing-survey123-part-1-white-label... to get started.
This video may also help.
