Beginner! Survey moderator
579
02-05-2018 03:43 AM
IssaHassan
I have created my first map app, It's a crowdsourcing, I send a survey form(Survey123) and every time someone fills the survey and submit, immediately a dot will show on the map. My question is how can I avoid the survey input to show up on the map immediately?  When someone submits a data on the survey, I want to approve or reject to be published on the map. How can I achieve this? I'm ArcGIS Online user. Thanks
ScottPrindle
Hey Issa,
I've shared this discussion with the https://community.esri.com/groups/survey123?sr=search&searchId=c7a12968-2983-48f1-9e27-c52e4fbe12ba&...‌ group to see if the community has some more insight on this. Are you using Survey123 Connect or the Survey123 Website to create your crowdsourcing surveys? What kind of approval process are you hoping to put in place before survey points appear in the map?
-Scott
JamesTedrick
Esri Esteemed Contributor
Hi Issa,
You asked this in https://community.esri.com/thread/209163-survey-moderation , correct?  Are you viewing the map in the Survey123 website, or another web map/app in ArcGIS Online?
James
