AnsweredAssumed Answered
Snapping doesn't work when many enterprise layers load
Question asked by NEOMAPPER on Feb 2, 2018
Latest reply on May 1, 2019 by ekoester
I am using Arcmap 10.6, when I have only limited number of enterprise layers loaded, the snapping experience process is painful. My cursor turns to "Busy" shape (the blue circle) and can't snap to the feature. I have no idea why it happens. Any solution?
Notes: Everything is hosted on a server through a Virtual Machine. The virtual machine includes all the mapping software for an enterprise level, along with SQL 2012.
Mapping Software: Version 10.6
ArcGIS Server
Portal for ArcGIS
Two ArcGIS Web Adaptors
SQL Server 2012
Operating System
Windows Server 2012 R2
Memory
32 gigs
Internet Bandwidth
50/50 mbps up/down
Tested:
  1. Rebuilt the entire map..
  2. Checked the map's data source in ArcCatalog
  3. Ran MXD Doctor
  4. Restarted ArcGIS services in Services
  5. Set the Default map as Default_old and generated another Default map
  6. Full Compression (Includes Reconcile & Post w/ Rebuild Indexes) Python ~ nightly routine w/ log (Successful)
  7. Restricted memory limits in SQL
  8. Checked the snapping tool bar
  9. Checked the tables
  10. Restarted the database
When editing is turn off the map is VERY quick to cache/load the object. Once you begin editing you're unable to snap features.
p.s. The local file geodatabases are not affected by this weird issue.
Outcomes
