AnsweredAssumed Answered
Is there a way to create a multilayer cache map image layer in ArcGIS Pro that is shared with the Portal 10.4.1?
Question asked by sescalan on Feb 2, 2018
Latest reply on Feb 2, 2018 by jskinner-esristaff
I am needing to cache multiple map image layers, IE Water Distribution map image layer with 3 feature layers (Main Lines, Hydrants, and Valves, in order to display them in a web map/app in Portal. It seems as though the options are to either share as a web map/web layer and cache the layers, and in turn not have the ability to turn feature layers on/off. Or, share the web map/web layer & map image layer where the data is drawn dynamically from the server and thus making one's map lag and unresponsive.
Everything I am finding on multilayer caches is using an older version of ArcMap. Am I missing something? Should I publish the layers as something else? What is the best strategy for having layers like this on a general reference type web map where every feature layer can be turned on or off, and a majority of the data is cached to allow for smooth operation?
Outcomes
