Relevant field syntax - any different from Kobo using XLSForm?
1068
02-01-2018 08:57 PM
wesleyPryor
I'm exploring options for porting over from Kobo. In importing xlsx docs, one major problem so far arises
We generate 'acknowledge' question based on calculations. XLS form syntax (works on kobo) is: [in relevant column] ${calc_mild} = '1' and ${calc_moderate} = '0'
where the ${calc_moderate} names refer to calculations based on earlier answers.
Using Survey 123, the app just says 'trigger' rather than the acknowledge message - doesnt seem to read the syntax in the same way as kobo.
Grateful for any guidance or more detailed information about relevant fields.
w
JamesTedrick
Esri Esteemed Contributor
Hi Wesley,
Currently, Survey123 does not support the acknowledge question type.  As an alternative, other customers have used a combination of notes and/or select questions to replicate the intention of acknowledge within a form.
wesleyPryor
Many thanks.
Is there a list of incompatibilities question types and syntax anywhere? I am most interested in any lurking issues with calculations, relevant syntax, selected-at, etc.
Thanks in advance and for your previous response.
Wes
JamesTedrick
Hi Wesley,
To our knowledge, the list of functions currently not supported are:
  • jr:choice-name
  • selected-at
  • indexed-repeat
  • boolean-from-string
  • join
  • decimal-date
  • decimal-time
  • checklist
  • weighted-checklist
  • position
  • area
Additionally, the choice_filter property is limited in terms of the complexity of formula it can accept- it currently does not accept functions.
