RicardoLopez
Checking and enforcing dowstream Z constraint for synthetic streams
Discussion created by RicardoLopez on Feb 2, 2018
Latest reply on May 1, 2018 by RicardoLopez
Assume I've delineated planar (X, Y) stream breaklines to use them for enforcement of bare ground DEM derivation from high density lidar data (about 1 ground point per square meter or greater). To convert them into 3D breaklines I use a conflation process (InterpolateShape) to populate the Z from the same lidar. Before using them for hydro enforcement in DEM derivation, one needs to see that the vertex elevations decrease monotonically in the downstream direction -due to ground vegetation noise and/or leftover structures in the lidar this is not always the case. Does anybody know of a tool/code to:
  • Check for downstream elevation monotonic decrease? The tool would detect and tag (by feature ID and measure?), polyline segments where the stream deviates from strict downstream gradient. An illustration:
  • Enforce the downstream Z monotonicity when errors are found? After enforcement the stream above would look something like:
It seems the functionality exists in the Defense Mapping + Production Mapping extensions (see http://desktop.arcgis.com/en/arcmap/latest/extensions/defense-mapping/correcting-monotonicity-errors.htm), but these are of restricted distribution.
Thanks!
Outcomes
