Is any tool similar to Densify tool that would create a new output feature class based on the input feature instead of modifying the original feature class?
1275
02-01-2018 02:15 PM
Azalea_KamelliaAbdullah1
I am trying to find a way to create point features based on a polyline feature class with a constant distance between them. I tried the 'Create points along line' tool but it generates an inaccurate output feature class; the distance between the points generated are not consistent.
So, I've been trying to go about it by executing the 'Densify' tool; configuring the distance that I want, and then implementing the 'Create Points from Vertices' tool to generate the points based on the vertices.
The thing is, is there a way to go about this without modifying the original line feature class? Any ideas anyone?
DanPatterson_Retired
yes... Densify By Factor developed and tested in ArcGIS PRO 2.0/2.1
If you are looking for exact functionality... then make a copy of the existing featureclass and densify it
