Raster Calculation and Weighted Sum
1225
5
01-31-2018 04:49 PM
deleted-user-wXI1z2K2eX3q
I am attempting to create a cost surface that incorporates the use of a DEM (slope raster), a Landcover Raster, Strahler stream order raster, lakes raster, roads raster, and a trails raster. I am under the assumption that the traveler will ALWAYS choose the trail or the road. I have many start and end points to run my least cost paths. I have also already reclassified all the rasters to a common scale.
I would like to know if there is anyone who knows how it is possible for me to somehow burn the roads and trails rasters into the other rasters. I would like the trails and roads to retain a value of "1" after raster calculation or weighted sum, while all other raster values are added together. Is this possible without weighting each raster differently?
DanPatterson_Retired
you can obviously just use the Con tool  if the road layer exists on its own, and your cost surface is another layer, it would be in the form
Con("Road" == 1, 1, "CostSurface")  assuming your roads are classed as 1 and non-road 0
Check the examples in the help topics and on GeoNet, there are ton of 'Con' examples
Obviously. Thank you, Dan.
Raymond, I meant 'obviously' in that there is so little in the strictly 'conditional' toolset to choose from.
Con should be renamed 'Where'
# ---- make a cost surface -----
costsurface = np.random.randint(2, 20, size=(10, 10))
# ---- make some roads ----
roads = np.zeros_like(costsurface)
roads[:, 2] = 1
roads[2, :] = 1
roads
array([[0, 0, 1, 0, 0, 0, 0, 0, 0, 0],
       [1, 1, 1, 1, 1, 1, 1, 1, 1, 1],
       [0, 0, 1, 0, 0, 0, 0, 0, 0, 0]])
# ---- Find out 'where' the roads are in the cost surface ---
# and 'embed' into it
embedded = np.where(roads == 1, roads, costsurface)
embedded
array([[ 6,  3,  1, 17, 16,  8,  5,  5,  2, 13],
       [13,  3,  1,  7,  6, 10,  7, 17,  5, 15],
       [ 1,  1,  1,  1,  1,  1,  1,  1,  1,  1],
       [14,  6,  1,  6, 10, 14, 15,  5,  9,  7],
       [ 4, 18,  1, 13, 11, 12, 16, 15,  3, 12],
       [ 7,  3,  1, 14,  3, 15, 19, 19, 12, 12],
       [ 7, 11,  1, 19,  7,  4, 13,  2, 11,  8],
       [17, 19,  1,  9,  9, 14, 14, 15, 13,  5],
       [11,  2,  1, 15,  8,  3, 15,  4, 19, 11],
       [17,  4,  1,  7,  2,  7,  7, 12, 12,  9]])
No worries! I must have read your reply during a state of frustration . I really appreciate your swift and accurate response! Con tool worked beautifully.
Glad it worked out Raymond
