How to show center point icon on a Map?
1513
01-31-2018 08:03 AM
Shane_
Hi, I'm showing a map from an MVC application using the js 4.6 api. The SceneView displays fine, at the correct zoom level and center point:
var view = new SceneView({
container: "map_canvas", map: map, scale: 50000, center: [@Model.LONGITUDE, @Model.LATITUDE]
I also need to display an icon at the center point of the map, with a label, which is clickable to show its attributes. I tried to do this using:
var features = [{
geometry:{type: "point",x: @Model.LONGITUDE,y: @Model.LATITUDE},
attributes:{ObjectID: 1,DepArpt: "KATL",MsgTime: Date.now(),FltId: "UAL1"}
var pointsLayer = new FeatureLayer({
source: features
map.addLayer(pointsLayer);
I don't get any error but the point doesn't show up. Any help would be appreciated. Thanks!
Here's the rest of the code:
<link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
<script src="https://js.arcgis.com/4.6/"></script>
<style>
#map_canvas img {
max-width: none;
</style>
<div id="map_canvas" style="height: 550px;"></div>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/PictureFillSymbol",
"esri/Color",
"esri/Graphic",
"esri/layers/FeatureLayer",
"dojo/dom", "dojo/on", "dojo/domReady!"
], function (Map, SceneView, Draw, Point, SimpleMarkerSymbol, SimpleLineSymbol, PictureFillSymbol, CartographicLineSymbol, Graphic, Color, dom, on) {
var map = new Map({
basemap: "hybrid", //streets, satellite, hybrid, topo, gray, dark-gray, oceans, osm, national-geographic
ground: "world-elevation",
sliderStyle: "large"
RobertScheitlin__GISP
Shane,
   There is no need to use a FeatureLayer for this instead use a Graphic:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Add Graphics to a SceneView - 4.6</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/Map",
        "esri/layers/GraphicsLayer",
        "esri/Graphic",
        "dojo/domReady!"
      function(
        Map, SceneView, GraphicsLayer, Graphic
        var map = new Map({
          basemap: "hybrid"
          container: "viewDiv",
          map: map,
          camera: { // autocasts as new Camera()
            position: { // autocasts as new Point()
              x: -0.17746710975334712,
              y: 51.44543992422466,
              z: 1266.7049653716385
            heading: 0.34445102566290225,
            tilt: 82.95536300536367
         * Add graphics layer
        var graphicsLayer = new GraphicsLayer();
        map.add(graphicsLayer);
         * Add a 3D point graphic
        // London
        var point = {
          type: "point", // autocasts as new Point()
          x: -0.178,
          y: 51.48791,
          z: 0
        markerSymbol = {
          type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
          color: [226, 119, 40],
          outline: { // autocasts as new SimpleLineSymbol()
            color: [255, 255, 255],
            width: 2
        var graphic = new Graphic({
          geometry: point,
          symbol: markerSymbol
        graphic.attributes = {
          "name": "Spruce",
          "family": "Pinaceae",
          "count": 126
        graphic.popupTemplate = {
          content: "<p>Name, <b>{name}</b></p>" +
            "<ul><li>Tree family: {family}</li>" +
            "<li>Count: {count}</li><ul>"
        graphicsLayer.add(graphic);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
KenBuja
MVP Esteemed Contributor
The order of the modules you're loading in require don't match the arguments in the function. You're missing several modules (Draw, Point, CartographicLineSymbol), some arguments are out of order (Graphic, Color), and not including arguments (FeatureLayer)
require([
"esri/Map",
"esri/Color",
"esri/Graphic",
Shane,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
        "esri/Map",
        "esri/Graphic",
        "dojo/domReady!"
      function(
        var map = new Map({
          basemap: "hybrid"
          map: map,
        // London
        var point = {
          x: -0.178,
          y: 51.48791,
          z: 0
        markerSymbol = {
            width: 2
          geometry: point,
          "name": "Spruce",
          "count": 126
  </script>
</head>
<body>
</body>
</html>
Shane_
Thanks Robert. Worked a treat!
