AnsweredAssumed Answered
GP Service - retain absolute file path
Question asked by paul.haakma on Jan 31, 2018
Latest reply on Feb 2, 2018 by JQuinn-esristaff
Hi all.
We have a python script that is being published to a GP service. One of the things it does is create a PDF file and save it. When run direct from ArcMap it saves correctly to the designated folder, but then when we publish the script to a GP service, it replaces the file path with a relative path.
We want the file path to remain absolute in this case - the target directory is permanent and accessed by other applications. In our tests we are just using a local directory, although in the production environment it is likely to be a mapped network drive.
We have tried a basic string such as r'd:\myfolder\myfile.pdf' and also os.path.join(r'd:\myfolder', 'myfile.pdf').
Our currently workaround is to edit the script file once published and replace the path again, but that seems rather hacky. It seems like there should be another, simpler way!
Any suggestions?
Regards,
-Paul
Outcomes
