Seperate JS files
2832
12
01-31-2018 06:43 AM
jaykapalczynski
I have an app that is starting to get a rather large amount of JS.
I was wondering if I could start to separate certain bits of code in a separate JS file and then just reference them.
If I reference it in HTML as I do the main JS file I get errors saying the map is not defined.
<script src="js/index.js"></script>
<script src="js/elevationprofile.js"></script>
Is there a way to reference all the split out JS files in the main JS file?
KenBuja
MVP Esteemed Contributor
So if I comment out almost all of the requires, leaving
require([
   "esri/map", "esri/geometry/webMercatorUtils", "dojo/dom", "dojo/parser",//"esri/dijit/Legend", //"esri/symbols/SimpleFillSymbol",
    //      "esri/geometry/Extent", "esri/layers/ArcGISDynamicMapServiceLayer", 'esri/layers/WMSLayer', 'esri/layers/WMSLayerInfo', "esri/layers/ImageParameters",
    //      "dojo/_base/array", "dojo/on", "esri/graphic", "esri/graphicsUtils", "esri/tasks/Geoprocessor", "esri/tasks/FeatureSet", "esri/tasks/LinearUnit", "esri/symbols/SimpleLineSymbol",
    //      "esri/renderers/SimpleRenderer", "esri/symbols/SimpleMarkerSymbol", "esri/layers/LabelClass", "esri/dijit/BasemapToggle", "esri/dijit/HomeButton", "esri/dijit/Search", "esri/dijit/LocateButton",
    //    "esri/urlUtils", "esri/dijit/Directions",
    //      "esri/toolbars/draw", "esri/symbols/CartographicLineSymbol", "esri/units", "esri/dijit/ElevationProfile",
    //      "esri/Color", "dojo/_base/array",  "esri/InfoTemplate", "esri/renderers/ClassBreaksRenderer", "dijit/form/CheckBox", "dojo/dom-construct",
    //      "dojo/keys", "esri/SnappingManager", "esri/dijit/Measurement", "esri/tasks/GeometryService", "esri/config", "esri/sniff", "esri/dijit/BasemapGallery",
    //      "esri/layers/LabelLayer", "esri/symbols/TextSymbol", "esri/symbols/Font", "esri/symbols/SimpleLineSymbol",
    //    "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "esri/dijit/Scalebar", "dijit/TitlePane", "dojo/domReady!"
 "dojo/domReady!"
], function (Map, webMercatorUtils, dom, parser
    //Map, webMercatorUtils, dom, FeatureLayer, Legend, SimpleFillSymbol,
    //  Extent, ArcGISDynamicMapServiceLayer, WMSLayer, WMSLayerInfo, ImageParameters,
    //  array, on, Graphic, graphicsUtils, Geoprocessor, FeatureSet, LinearUnit, SimpleLineSymbol,
    //  SimpleRenderer, SimpleMarkerSymbol, LabelClass, BasemapToggle, HomeButton, Search, LocateButton,
    //urlUtils, Directions,
    //  Draw, CartographicLineSymbol, Units, ElevationsProfileWidget,
    //  Color, arrayUtils, parser, InfoTemplate, ClassBreaksRenderer, CheckBox, domConstruct,
    //  keys, SnappingManager, Measurement, GeometryService, esriConfig, has, BasemapGallery,
    //  LabelLayer, TextSymbol, Font, SimpleLineSymbol
then the code works. If I uncomment the next module, "esri/layers/FeatureLayer", then the code fails. The time it takes to load all those modules was causing a problem. To fix that, I used dom/ready on the other js file. This makes
require(["dojo/ready", "esri/map", "dojo/domReady!"], function (ready, Map) {
    ready(function () {
        map.on("click", function (e) {
            alert("clicked");
From the documentation
dojo/ready registers a function to run when the DOM is ready and all outstanding require() calls have been resolved, and other registered functions with a higher priority have completed.
jaykapalczynski
I tried this:
Added this to HTML under my main js file
<!-- New reference to js file  -->
<script src="js/elevationprofile.js"></script> ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
<!-- SNIP -->
<div id="map" class="shadow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="region:'center'" style="height:100%">
    <div id="LocateButton" data-dojo-props="region:'center'"></div>
     <div id="HomeButton"></div>
     <div id="search"></div>
        <div id="profilecontainer" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'" >
     <div id="profileChartNode"></div>
    </div>
</div>
Added this new js file
require([
     "esri/map","dojo/domReady!"
], function(
     Map
    map.on("click", function(e){
        alert("clicked");
I get this error:
init.js:28 Uncaught TypeError: map.on is not a function
    at elevationprofile.js:7
    at ia (init.js:28)
    at init.js:28
    at ja (init.js:28)
    at ga (init.js:28)
    at f (init.js:30)
    at HTMLScriptElement.<anonymous> (init.js:35)‍‍‍‍‍‍‍‍
KenBuja
Where are you setting a reference to "map"?
jaykapalczynski
I'm not in the 2nd js file...I was following this example towards the bottom.  They dont set the reference in the 2nd js file as I can see.
creating javascript external file for map function
confused.
I am doing so in the main js file
var map = new Map("map", {
  basemap: "gray",
  center: [-79.665, 37.629],
  zoom: 8,
  logo: false,
  showLabels : true
KenBuja
If you look at the other example, it declares "map" outside the require section in the first js file. You're declaring it inside.
var map;
require(["esri/map", "dojo/domReady!"],function(Map) {
    basemap: "topo",
    center: [-122.45, 37.75], // longitude, latitude
    zoom: 13
jaykapalczynski
Yea thats what I am doing....in the original js file
      require([
        "esri/map", "esri/geometry/webMercatorUtils", "dojo/dom", "esri/layers/FeatureLayer", "esri/dijit/Legend","esri/symbols/SimpleFillSymbol",
          "dojo/_base/array", "dojo/on", "esri/graphic","esri/graphicsUtils","esri/tasks/Geoprocessor","esri/tasks/FeatureSet","esri/tasks/LinearUnit","esri/symbols/SimpleLineSymbol",
          "esri/renderers/SimpleRenderer", "esri/symbols/SimpleMarkerSymbol","esri/layers/LabelClass", "esri/dijit/BasemapToggle","esri/dijit/HomeButton", "esri/dijit/Search", "esri/dijit/LocateButton",
          "esri/toolbars/draw","esri/symbols/CartographicLineSymbol","esri/units","esri/dijit/ElevationProfile",
          "esri/Color", "dojo/_base/array", "dojo/parser", "esri/InfoTemplate", "esri/renderers/ClassBreaksRenderer","dijit/form/CheckBox", "dojo/dom-construct",
          "dojo/keys","esri/SnappingManager","esri/dijit/Measurement","esri/tasks/GeometryService","esri/config",     "esri/sniff","esri/dijit/BasemapGallery",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer","esri/dijit/Scalebar","dijit/TitlePane", "dojo/domReady!"
      ], function(
          keys,SnappingManager, Measurement, GeometryService,esriConfig, has,BasemapGallery,
     var dojoConfig = { parseOnLoad: true };
        var legendLayers = [];
     parser.parse();
     // VARIABLES FOR ELEVATION WIDGET
     var tb, epWidget, lineSymbol;
     var gp, mapClickEvt;
      basemap: "gray",
      zoom: 8,
       logo: false,
       showLabels : true
// SNIP  bunch of code for other stuff
KenBuja
You have to declare variable "map" before line 1
var map;
require([
then on line 35, you would use
  basemap: "gray",
  zoom: 8,
  logo: false,
  showLabels : true
jaykapalczynski
I moved to the top in my main js file
var map;
 require([
      ], function(
    parser.parse();
      basemap: "gray",
      zoom: 8,
      logo: false,
      showLabels : true
I then have this in my 2nd js file
require([
    ], function(
        Map
        alert("clicked");
I know get this error
init.js:28 Uncaught TypeError: Cannot read property 'on' of undefined
at ia (init.js:28)
at init.js:28
at ja (init.js:28)
at ga (init.js:28)
at f (init.js:30)
KenBuja
require([
 "dojo/domReady!"
    ready(function () {
            alert("clicked");
jaykapalczynski
OK I removed dojo/domReady and replaced with dojo/ready and it works...go figure...
THANKS..
