feature
1048
8
01-30-2018 11:17 PM
anjelinaponkerat
Occasional Contributor II
I,m going to change portal item in edit sample and add feature layer, but no result:
var MyFeature = new FeatureLayer({
url: "https://localhost:6080/arcgis/rest/services/Texass_Layer/FeatureServer/4",
visible:true,
How to replace feature layer instead of portal item in this sample?:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Update FeatureLayer using applyEdits() - 4.6</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.6/esri/css/main.css">
<script src="https://js.arcgis.com/4.6/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.editArea-container {
background: #fff;
font-family: "Avenir Next W00", "Helvetica Neue", Helvetica, Arial, sans-serif;
line-height: 1.5em;
overflow: auto;
padding: 12px 15px;
width: 300px;
.edit-button:hover,
.edit-button:focus {
background-color: #e4e4e4;
.inputInfo {
font-size: 12px;
height: 32px;
margin-bottom: 6px;
padding: 0 6px;
width: 100%;
.list-heading {
font-weight: normal;
margin-top: 20px;
margin-bottom: 10px;
color: #323232;
.edit-button {
font-size: 14px;
height: 32px;
margin-top: 10px;
width: 100%;
background-color: transparent;
border: 1px solid #0079c1;
color: #0079c1;
.or-wrap {
background-color: #e0e0e0;
height: 1px;
margin: 2em 0;
overflow: visible;
.or-text {
background: #fff;
line-height: 0;
padding: 0 1em;
position: relative;
top: -.75em;
input:invalid {
border: 1px solid red;
input:valid {
border: 1px solid green;
</style>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/layers/Layer",
"esri/Graphic",
"esri/widgets/Expand",
"esri/widgets/Home",
"esri/geometry/Extent",
"esri/Viewpoint",
"esri/core/watchUtils",
"dojo/on",
"dojo/dom",
"dojo/domReady!"
function(
Map, SceneView, Layer, Graphic, Expand,
Home, Extent, Viewpoint, watchUtils,
on, dom
var featureLayer, editExpand;
// feature edit area domNodes
var editArea, attributeEditing, inputDescription,
inputUserInfo, updateInstructionDiv;
var map = new Map({
basemap: "streets"
// initial extent of the view and home button
var initialExtent = new Extent({
xmin: -13045631,
xmax: -13042853,
ymin: 4034880,
ymax: 4034881,
spatialReference: 102100
var view = new SceneView({
container: "viewDiv",
map: map,
extent: initialExtent
// add an editable featurelayer from portal
Layer.fromPortalItem({
portalItem: { // autocasts as new PortalItem()
}).then(addLayer)
.otherwise(handleLayerLoadError);
setupEditing();
setupView();
function addLayer(lyr) {
featureLayer = lyr;
map.add(lyr);
function applyEdits(params) {
unselectFeature();
var promise = featureLayer.applyEdits(params);
editResultsHandler(promise);
// applyEdits promise resolved successfully
// query the newly created feature from the featurelayer
// set the editFeature object so that it can be used
// to update its features.
function editResultsHandler(promise) {
promise
.then(function(editsResult) {
var extractObjectId = function(result) {
return result.objectId;
// get the objectId of the newly added feature
if (editsResult.addFeatureResults.length > 0) {
var adds = editsResult.addFeatureResults.map(
extractObjectId);
newIncidentId = adds[0];
selectFeature(newIncidentId);
.otherwise(function(error) {
console.log("===============================================");
console.error("[ applyEdits ] FAILURE: ", error.code, error.name,
error.message);
console.log("error = ", error);
// listen to click event on the view
// 1. select if there is an intersecting feature
// 2. set the instance of editFeature
// 3. editFeature is the feature to update or delete
view.on("click", function(evt) {
unselectFeature();
view.hitTest(evt).then(function(response) {
if (response.results.length > 0 && response.results[0].graphic) {
var feature = response.results[0].graphic;
selectFeature(feature.attributes[featureLayer.objectIdField]);
inputDescription.value = feature.attributes[
"Incident_Desc"];
inputUserInfo.value = feature.attributes[
"Incident_Address"];
attributeEditing.style.display = "block";
updateInstructionDiv.style.display = "none";
// select Feature function
// 1. Select the newly created feature on the view
// 2. or select an existing feature when user click on it
// 3. Symbolize the feature with cyan rectangle
function selectFeature(objectId) {
// symbol for the selected feature on the view
var selectionSymbol = {
type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
color: [0, 0, 0, 0],
style: "square",
outline: {
color: [0, 255, 255, 1],
width: "3px"
var query = featureLayer.createQuery();
query.where = featureLayer.objectIdField + " = " + objectId;
featureLayer.queryFeatures(query).then(function(results) {
if (results.features.length > 0) {
editFeature = results.features[0];
editFeature.symbol = selectionSymbol;
view.graphics.add(editFeature);
// hide attributes update and delete part when necessary
function unselectFeature() {
attributeEditing.style.display = "none";
updateInstructionDiv.style.display = "block";
inputDescription.value = null;
inputUserInfo.value = null;
view.graphics.removeAll();
// add homeButton and expand widgets to UI
function setupView() {
// set home buttone view point to initial extent
var homeButton = new Home({
view: view,
viewpoint: new Viewpoint({
targetGeometry: initialExtent
view.ui.add(homeButton, "top-left");
// expand widget
editExpand = new Expand({
expandIconClass: "esri-icon-edit",
expandTooltip: "Expand Edit",
expanded: true,
view: view,
content: editArea
view.ui.add(editExpand, "top-right");
// set up for editing
function setupEditing() {
// input boxes for the attribute editing
editArea = dom.byId("editArea");
updateInstructionDiv = dom.byId("updateInstructionDiv");
attributeEditing = dom.byId("featureUpdateDiv");
inputDescription = dom.byId("inputDescription");
inputUserInfo = dom.byId("inputUserInfo");
// btnUpdate click event
// update attributes of selected feature
on(dom.byId("btnUpdate"), "click", function(evt) {
if (editFeature) {
editFeature.attributes["Incident_Desc"] = inputDescription.value;
editFeature.attributes["Incident_Address"] = inputUserInfo.value;
var edits = {
updateFeatures: [editFeature]
applyEdits(edits);
// btnAddFeature click event
// create a new feature at the click location
on(dom.byId("btnAddFeature"), "click", function() {
unselectFeature();
on.once(view, "click", function(event) {
event.stopPropagation();
if (event.mapPoint) {
point = event.mapPoint.clone();
point.z = undefined;
point.hasZ = false;
newIncident = new Graphic({
geometry: point,
attributes: {}
var edits = {
addFeatures: [newIncident]
applyEdits(edits);
// ui changes in response to creating a new feature
// display feature update and delete portion of the edit area
dom.byId("viewDiv").style.cursor = "auto";
else {
console.error("event.mapPoint is not defined");
// change the view's mouse cursor once user selects
// a new incident type to create
dom.byId("viewDiv").style.cursor = "crosshair";
editArea.style.cursor = "auto";
// delete button click event. ApplyEdits is called
// with the selected feature to be deleted
on(dom.byId("btnDelete"), "click", function() {
var edits = {
deleteFeatures: [editFeature]
applyEdits(edits);
// watch for view LOD change. Display Feature editing
// area when view.zoom level is 14 or higher
// otherwise hide the feature editing area
view.when(function() {
watchUtils.whenTrue(view, "stationary", function() {
if (editExpand) {
if (view.zoom <= 14) {
editExpand.domNode.style.display = "none";
else {
editExpand.domNode.style.display = "block";
function handleLayerLoadError(err) {
console.log("Layer failed to load: ", err);
</script>
</head>
<body>
<div id="editArea" class="editArea-container">
<div id="addFeatureDiv">
<h3 class="list-heading">Report Incidents</h3>
<ul style="font-size: 13px; padding-left: 1.5em;">
<li>Click Add incident button</li>
<li>Click on the map to create the incident</li>
</ul>
<input type="button" class="edit-button" value="Add incident" id="btnAddFeature">
</div>
<div id="updateInstructionDiv" style="text-align:center">
<p class="or-wrap"><span class="or-text">Or</span></p>
<p>Select an incident to edit or delete.</p>
</div>
<div id="featureUpdateDiv" style="display:none; margin-top: 1em;">
<h3 class="list-heading">Enter the incident information</h3>
<div id="attributeArea">
<label for="inputDescription">Description:</label>
<input class="inputInfo" type="text" id="inputDescription" placeHolder="Enter description"><br>
<label for="inputUserInfo">Contact:</label>
<input class="inputInfo" required type="email" name="email" id="inputUserInfo" pattern="[^ @]*@[^ @]*"
placeHolder="Enter email address"><br>
<input type="button" class="edit-button" value="Update incident info" id="btnUpdate">
</div>
<div id="deleteArea">
<input type="button" class="edit-button" value="Delete incident" id="btnDelete">
</div>
</div>
</div>
<div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
You are right. I forgot to add FeatureLayer to the require array. I have updated the code I originally posted.
Anjelina,
  You still have to learn how to use the syntax highlighter on GeoNet... It just makes it so much easier for us to read your code. Posting code with Syntax Highlighting on GeoNet
Lines 131-149 edited. And added FeatureLayer to require list.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      background: #fff;
      line-height: 1.5em;
      overflow: auto;
      padding: 12px 15px;
      width: 300px;
    .edit-button:hover,
    .inputInfo {
      font-size: 12px;
      height: 32px;
      margin-bottom: 6px;
      padding: 0 6px;
      width: 100%;
    .list-heading {
      margin-top: 20px;
      color: #323232;
    .edit-button {
      font-size: 14px;
      height: 32px;
      margin-top: 10px;
      width: 100%;
      color: #0079c1;
    .or-wrap {
      height: 1px;
      margin: 2em 0;
      overflow: visible;
    .or-text {
      background: #fff;
      line-height: 0;
      padding: 0 1em;
      position: relative;
      top: -.75em;
    input:invalid {
    input:valid {
  </style>
  <script>
    require([
        "esri/Map",
        "esri/Graphic",
        "esri/Viewpoint",
        "dojo/on",
        "dojo/dom",
        "esri/layers/FeatureLayer",
        "dojo/domReady!"
      function(
        on, dom, FeatureLayer
        var map = new Map({
          basemap: "streets"
          xmin: -13045631,
          xmax: -13042853,
          ymin: 4034880,
          ymax: 4034881,
          map: map,
        // Layer.fromPortalItem({
        //     portalItem: { // autocasts as new PortalItem()
        //       id: "511b97fc0d364367b127f8ba5c89ad13"
        //   }).then(addLayer)
        //   .otherwise(handleLayerLoadError);
        addLayer();
        setupEditing();
        setupView();
        function addLayer() {
          featureLayer = new FeatureLayer({
            visible:true
          map.add(featureLayer);
          unselectFeature();
          promise
                  extractObjectId);
                error.message);
          unselectFeature();
                "Incident_Desc"];
            style: "square",
            outline: {
              width: "3px"
            view: view,
          // expand widget
            expanded: true,
            view: view,
            content: editArea
            if (editFeature) {
              var edits = {
              applyEdits(edits);
            unselectFeature();
                point.hasZ = false;
                  geometry: point,
                  attributes: {}
                var edits = {
                applyEdits(edits);
              } else {
            var edits = {
            applyEdits(edits);
              if (editExpand) {
                } else {
  </script>
</head>
<body>
      </ul>
    </div>
    </div>
        <input class="inputInfo" required type="email" name="email" id="inputUserInfo" pattern="[^ @]*@[^ @]*" placeHolder="Enter email address"><br>
      </div>
      </div>
    </div>
  </div>
</body>
</html>
anjelinaponkerat
can not show feature layer and can not edit or add new points ...
anjelinaponkerat
But I have a problem, when I use my own service, because of different fields in features, I can not update points, I changed :
to my fields:
   editFeature.attributes["City"] = inputDescription.value;
              editFeature.attributes["Phone_Number"] = inputUserInfo.value;
and change:
                "Incident_Desc"];
 to my fields:
                "City"];
                "Phone_Number"];
but it can not load info from feature service to it's text box and unfortunately return "undefined"
Anjelina,
  Are those the correct field names for your data CaSe and all?
anjelinaponkerat
yes exactly all fields name are correct. but I dont know why it does not work.
Anjelina,
   Did you specify the outFields for your feature layer?
            url: "http://gis.calhouncounty.org/arcgis2/rest/services/CountyCrimeMap/FeatureServer/0",
            visible: true,
            outFields: ["*"]
anjelinaponkerat
The problem was related to "outfields"
