Calculate Field Problem in Model Builder
3013
13
01-30-2018 08:38 AM
KyleBalke__GISP
Occasional Contributor III
When attempting to open the Calculate Field tool within an existing Model Builder model the expression section does not appear however I can see the expression when hovering over the tool.  The model was built with Pro 2.0 and I am first seeing this issue after upgrading to Pro 2.1.  Has anyone else experienced this issue?
DanPatterson_Retired
Was it a parameter? (ie a P beside the calculate field or one of its variables)
You may have to edit the model in 2.1 if it was fine in 2.0.
KyleBalke__GISP
The expression did use a parameter and in-line variable substitution...I am currently editing in 2.1 and that is where I am experiencing this issue.  If I add a completely new Calculate Field tool to the model the expression section is available.  Seems to be a bug to me when moving from 2.0 to 2.1.  However I did notice that 2.0 was using PYTHON_9.3 as the expression type which is no longer an available option in 2.1 (now Python 3).
Edit:  Based on the Calculate Field help legacy Python and Python 9.3 expressions are supported.
KyleBalke__GISP
Here are two screenshots:
sure enough Calculate Field in modelbuilder has been significantly changed
http://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/modelbuilder/modelbuilder-changes-in-ar...
KyleBalke__GISP
True...unfortunately my situation does not involve a migration from Desktop to Pro.  The model was built in Pro originally .  On the plus side I was able to expose the Code Block as a parameter in one of the tools and access the code I need.  Unfortunately the same is not true for the expression section so I am currently having to re-building each Calculate Field tool.  I appreciate your help Dan_Patterson
Sorry, I couldn't find any mention anywhere of an issue... you might want to forward this to tech support especially since Beta 2.2 will be beginning and this could be put on the plate
ShitijMehta
Hi Kyle Balke,
This is a know issue. We are working to fix it. This behavior exhibits only in few cases. To get past this bug please re-add the calculate value tool. If you could share the repro steps you took that led to the tool getting in this state. For example, did you share the toolbox or model? copy pasted it? added in previous release and now it just shows like this in 2.1? Also, If you can share the original model that would help us take care of all fringe cases. Thanks!
KyleBalke__GISP
Hi Shitij Mehta
Apologies for the delayed response.  The original model was built in 2.0.  There are at least half a dozen instances of the Calculate Field tool being used in a single model and there is a high likely-hood that I used a copy/paste from the first instance of the tool that was added to the model.  The issue described in the original post  occurred only after upgrading to 2.1.
Not addressed in the dot updates to 2.1?
More importantly, why would a copy/paste operation contribute or cause the error?
