Georeferencing with jpeg compression
751
01-29-2018 02:18 AM
ThorstenBrune1
I tried to georeference a picture in ArcGIS 10.4.1. In order to reduce data size I want to save the georeferenced picure in a jpg-format.
Unfortunately following message appears: "Output file format with specified type of pixel, specified number of channel or specified colourmap would not be supported. Read help chapter "technical specification for raster datasets".
I have read the help chapter but I dont know any solution. Jpeg2000 doesnt work either. In which case is a jpeg compression possible? Is it possible to convert a picture in another picture format before compressing it?
DanPatterson_Retired
georeferenced first, then use Copy Raster you can specify the type and compression where applicable
