Web scene sharing error 24078
682
01-26-2018 06:13 AM
larryzhang1
New Contributor III
Hi, ArcGIS Online/3D teams:
I tested a web scene , which contains a 3D model with textured meshes created with Bentley ContextCapture.
And have the following findings:
  • Pro 2.1.0 produces an error message: the layer data source is not supported in ArcGIS Online. However,
  • The layer package of this 3D integrated meshes model (with Bentley ContextCapture) can be loaded and shared over ArcGIS Online with Desktop ArcGIS Pro and ArcGIS Earth.
The question is:
  • Why not to be supported in ArcGIS Online?  Technically or others?
  • Note, Bentley ContextCaputute follows ESRI open scene standard i3s to produce this 3D integrated meshes model, which were supported in 2016. See the link . In fact, some of the samples from Bentley "were" available online , but not true anymore.
Tags (1)
Andrew--Johnson
Hi Larry,
Did you try using the Share Package tool to share the data to ArcGIS Online? If you have a SLPK this is the workflow for sharing the data to AGOL or Portal. If you had the original feature data and wanted to create a scene layer in AGOL then that is when you would use the share as web layer or share as web scene workflow.
