Upgrading apps to WAB 2.7 ?
767
01-25-2018 11:21 AM
chintakandel
New Contributor III
In Command Prompt window, I navigate to WAB 2.7 \server directory and type this command:
node_x86 upgrade D:\arcgis_web_appbuilder_2.6\WebAppBuilderForArcGIS
Error: ‘node_x86’ is not recognized as an internal or external command.
Again tried,
node_x64 upgrade D:\arcgis_web_appbuilder_2.6\WebAppBuilderForArcGIS
Both command throws same error.
Command works until WAB 2.6. I wonder whether it is due to Node version or something different in WAB 2.7?
I checked Node version in my computer: V 5.7.1
Any thoughts?
Thanks in advance!
Tags (1)
RobertScheitlin__GISP
I always use elevated privileges and I just tested upgrading 2.6 to 2.7 and it worked fine for me.
Chintamani,
  Did you open the cmd.exe using elevated privileges (i.e. right click and choose run as administrator)?
chintakandel
New Contributor III
Hi Robert,
Thank you for your suggestion. I installed WAB in D drive. It was working without elevated privileges for WAB 2.5 and 2.6.
chintakandel
New Contributor III
Thank you Robert. I will use elevated privileges to upgrade apps.
