AnsweredAssumed Answered
Feature Layer Graphics Limitation via Source
Question asked by dbmangrum_dev on Jan 25, 2018
Latest reply on Oct 26, 2018 by liwei72439936@gmail.com
I'm trying to load a simple Map & MapView with a single Feature Layer and am seeing some serious performance degradation when I attempt to load the layer with thousands of features.
I'm using the ArcGIS JS API v4.6.
I'm not loading the Feature Layer graphics via an ArcGIS Feature Service URL, but rather loading it client side via the "source" property.
If I limit the number of features to 1000 the map becomes responsive.
If I load the Feature Layer with an ArcGIS Feature Service URL the map is fully responsive even when rendering 30,000+ features.
The data set I'm using to load the Feature Layer locally via the "source" property is a small subset of the data available on the Feature Service, and the graphic I'm using is a very small SVG (approximately 600 bytes).
The reason for my question is to see if there is any known limitation to loading a Feature Layer's graphics client side via the source property, or if there is a way to emulate the optimization/rendering logic utilized when a Feature Layer is loaded from an ArcGIS Feature Service URL.
I've confirmed that my browser supports WebGL and have even added the "esri-featurelayer-webgl" setting to the dojoConfig in the <head> of my index.html file in order to enable WebGL for Feature Layers as seen here:
ArcGIS API for JavaScript Sandbox
<script>
var dojoConfig = {
has: {
// Enable webgl for feature layer in MapView
"esri-featurelayer-webgl": 1
</script>
Unfortunately i'm not seeing any effect of enabling this setting.  Hopefully someone can shed some light on what I'm doing wrong.
Dalton
Outcomes
