AnsweredAssumed Answered
Calculations from Survey123 to ArcGIS Online
Question asked by deleted-user-FTxtuSQd67Ur on Jan 24, 2018
Latest reply on Jan 25, 2018 by deleted-user-FTxtuSQd67Ur
When you have calculations that occur based on time in Survey123, does that calculation carry over when the survey is published to the web and used in AGOL?
For example, I have a survey that contains values that change depending on the date and I wondered if those will still work once the survey is published or do the values entered during the initial survey submitted stay static? If they are static then I suppose my other option would be to replicate the process using Arcade but I do not really want to do that since the calculations are done in a repeat group.
Thanks!
Outcomes
