AnsweredAssumed Answered
ArcPy Feature Class to Feature Class blank results - ArcGIS Pro
Question asked by bisoftware on Jan 23, 2018
Latest reply on Jan 26, 2018 by bisoftware
I have this Feature Class to Feature Class script that creates a feature class of patient visits for each store for every month for every year it has been open. However, when I run the script it will create feature classes by month and year with the correct labels, for example (Jan2015_NWPatientVisits2000Gresham), but when I look at the attribute table it contains no data.
I believe the problem is in my "expression" because when I alter it to run on only "USER_DOSYear" or "USER_DOSMonth" it will populate, but when I try and string them together that is when the problem occurs.
I'm sure I am missing something small, but I just can't seem to figure out what it is.
Here is my script:
import arcpy
# Set environment settings
arcpy.env.workspace = r"C:\arcGIS_Shared\Python\CenterHeatMaps.gdb"
#Declare variables
fc = 'Open_Store_Centers'
fields = ['USER_market_id','USER_Store_ID','USER_Store_Center_Name']
fieldname = 'USER_market_id'
#Define WHERE clause statement
whereclause = """{} = 2000""".format(arcpy.AddFieldDelimiters(fc, fieldname))
sqlclause = (None, 'Order By USER_market_id, USER_Store_ID')
# loop through months
years = [2015, 2016, 2017]
months = ['Jan', 'Feb', 'Mar', 'Apr', 'May', 'Jun', 'Jul', 'Aug', 'Sep', 'Oct', 'Nov', 'Dec']
for year in years:
    for month in months:
        with arcpy.da.SearchCursor(in_table = fc, field_names = fields, where_clause=whereclause, sql_clause=(None, 'ORDER BY USER_market_id, USER_Store_ID')) as cursor:
        #Loop through each row established in cursor
            for row in (cursor):
            # Set local variables for FeatureClasstoFeatureClass
                inFeatures = "PatientVisitsGeocoded"
                outLocation = r"C:\arcGIS_Shared\Python\CenterHeatMaps.gdb"
                outFeatureClass = "{2}{3}_NWPatientVisits{0}{1}".format(row[0], row[2], month, year)
                delimitedfield = arcpy.AddFieldDelimiters(arcpy.env.workspace,"USER_CenterID")
                expression = delimitedfield + "= {0}".format(row[1]) + " AND USER_DOSYear = {0}".format(year) + " AND USER_DOSMonth = '{0}'".format(month)
#         Execute FeatureClassToFeatureClass
                arcpy.FeatureClassToFeatureClass_conversion(inFeatures, outLocation, outFeatureClass, expression)
        #Print Results
                print(row[2])
                count = arcpy.GetMessageCount()
                print (arcpy.GetMessage(count-1))
Any help/advice would be much appreciated. Thanks.
Outcomes
