I am currently working with a Web AppBuilder template. I need to make sure that the layers required are added to the Web Map but I cannot figure out where or how to access the Web Map. Should I be adding the layers in some part of the Layer List widget?
Through the portal, I tried clicking on "Map" -> "Add" -> "Add Layer From Web." I have tried to pair my service url with every option in the drop down but I always get an error.
Thank you for any pointers.
Mansi,
To add layers to your web map you need to open the webmap in Portal and use the Add > Add layer from Web. I see that you have tried this and said there was an error. What url are you try to use? Is it a MapServer service from your ArcGIS Server?
