"If" Statement and Loop - ArcPy for ArcGIS Pro
4842
24
01-18-2018 11:26 AM
Business_IntelligenceSoftware
I have this code that performs a Summarize Within on all company stores for every month of the year. However, not all the stores were open in some of the early months so I need to write some code that will identify that the "USER_PatientVisits" is equal to zero and then skip that store and move on to the next. I'm thinking this can be accomplished using an "If" statement and probably a loop; however, I'm not sure what exactly to write and how to bring it all together.
Here is the top portion of my code for January and February; the full code continues on through December:
import arcpy
import sys
import os
import datetime
#now = datetime.datetime.now()
#Set the workspace
from arcpy import env
env.workspace = r"C:\arcGIS_Shared\Python\CenterHeatMaps.gdb"
#Declare variables
fc = 'Open_Store_Centers'
fields = ['USER_market_id','USER_Store_ID','USER_Store_Center_Name']
fieldname = 'USER_market_id'
#Define WHERE clause statement
whereclause = """{} = 2000""".format(arcpy.AddFieldDelimiters(fc, fieldname))
#Cursor to create list of centers to loop through
cursor = arcpy.da.SearchCursor(in_table = fc, field_names = fields, where_clause=whereclause, sql_clause=(None, 'ORDER BY USER_market_id, USER_Store_ID'))
#Loop to run SummarizeWithin by center
for row in (cursor):
    #  Set variables for SummarizeWithin
    #  Specify type of summarization, either Blocks or ZIPS, as part of the polys argument
    polys = "Market{0}".format(row[0])+"Blocks"
    points = "Jan_NWPatientVisits{0}".format(row[0])+"{0}".format(row[2])
    outFeatureClass = "Jan_NWSumWithin{0}".format(row[0])+"{0}".format(row[2])
    keepAll = 'ONLY_INTERSECTING'
    sumFields = [['USER_VisitCount', 'Sum']]
    addShapeSum = 'ADD_SHAPE_SUM'
    arcpy.SummarizeWithin_analysis(polys, points, outFeatureClass, keepAll, sumFields, addShapeSum, '')
    #Print Results
    print(row[2])
#    print("SumWithin Elapsed Time:" + SumWithinruntime)
#    count = arcpy.GetMessageCount()
#    print (arcpy.GetMessage(count-2))
    print (arcpy.GetMessages())
    #Declare variables
    points = "Feb_NWPatientVisits{0}".format(row[0])+"{0}".format(row[2])
    outFeatureClass = "Feb_NWSumWithin{0}".format(row[0])+"{0}".format(row[2])
    #Print Results
    print(row[2])
    print (arcpy.GetMessages())‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
Code formatting please  it is unreadable in its current state.  Try not to edit code once it is pasted in either, that seems to be what happened.  Edit in the source, then paste
Sorry about that. I don't know why it was in that format
Use the Python option within the syntax highlighter to get line numbers.
After this line
if points > 0:
    # then indent all your other lines
    # to continue the processing
    # just guessing since there are no line numbers
    # and portions of the code seem to be duplicated
XanderBakker
Esri Esteemed Contributor
Also when you feel that you are repeating code (like you now have a big block for Jan and another for Feb) it is time to use a loop. For instance have a list of the month prefixes that you want to use like months = ['Jan', 'Feb', ..., 'Dec'] and loop through the months. Something like this (ignoring any other changes that might be required in the code):
import arcpy
import sys
import os
import datetime
#Set the workspace
#Declare variables
whereclause = "{0} = 2000".format(arcpy.AddFieldDelimiters(fc, fieldname))
sqlclause = (None, 'ORDER BY USER_market_id, USER_Store_ID')
# loop through months
months = ['Jan', 'Feb', 'Mar'] # add all the months
for month in months:
    with arcpy.da.SearchCursor(in_table=fc, field_names=fields,
                               where_clause=whereclause, sql_clause=sqlclause) as cursor:
        for row in cursor:
            points = "{2}_NWPatientVisits{0}{1}".format(row[0], row[2], month)
            outFeatureClass = "{2}_NWSumWithin{0}{1}".format(row[0], row[2], month)
            #Print Results
            print(row[2])
Yes the code is duplicated for each month. Unfortunately, "if points > 0:" gives me the following error.
TypeError: unorderable types: str() > int()
I then tried adding " " around the zero to change it from an integer to a string, which allowed it to run, but it did not exclude the stores with zero visits
if points is a string then you need
if int(points) > 0:
Ok I think we are close. I'm now getting the following error.
ValueError: invalid literal for int() with base 10: 'Apr_CTPatientVisits4000Avon'
I think this is because technically the attribute table for 'Apr_CTPatientVisits4000Avon' is blank and does not contain zero.
Should it be "Null" instead?
and did you indent the code as well?
xander_bakker‌ could you try the indentation suggestion on your code to save a copy paste to show what I mean
Here is a little excerpt
    points = "May2_CTPatientVisits{0}".format(row[0])+"{0}".format(row[2])
    if int(points) > 0:
        outFeatureClass = "May_CTSumWithin{0}".format(row[0])+"{0}".format(row[2])
