uploading downloaded shapefile into ArcMap from soil survey website
568
01-18-2018 07:23 AM
GeorgeJones
hey all, i have recently downloaded an AOI shapefile from the  Web Soil Survey - Home  . I have tried dragging and dropping the above shapefile into ArcMap but ArcMap did not take it. I do have the right projection (WGS-84). Just wondering what am i missing. Thanks.
DanPatterson_Retired
Use the Add Data button, navigate to the folder and see if the shapefile is there.  What you have highlighted might not be a shapefile but something else, since the full file name isn't visible in your image
JosephCarter
I agree with Dan, George. Your clip looks like a Windows Explorer folder . . .drag from ArcCatalog or Add Data.
JayantaPoddar
MVP Esteemed Contributor
You don't add a shapefile from Windows Explorer.
Open ArcMap > Connect to folder (if not yet done) > Add Data > Navigate to the shapefile and add it to ArcMap.
Fig 1: Add Data option
Think Location
