When I execute the Erase Tool in ArcGIS it does not erase all of the features in the input class. The Input and Erase features are both polygons. I have attempted multiple times, hoping it was just a fluke.
Here is what I have tried so far:
1) I have selected out the specific features from the input that aren't being erased and attempted to run the Erase with those, but the output shapefile ends up being completely empty.
2) Using the Clip tool instead. The effects are the same.
3) Made sure when I run the Erase that no random features are accidentally selected.
4) Repair Geometry of input.
5) Rebuild Spatial Index of input.
Does anyone have experience about how to fix this problem?
Hey Dan Patterson so I found out what the problem was. I needed to change the Processing Extent within the Environments to "Union of Inputs." I thought you may be interested in the solution. Thank you so much for your help though!
