Resize popup when Maxmized
686
01-11-2018 08:12 AM
BrandonPrice
I would like to resize the esri popup when maxmized to a smaller size. I have not been able to do it using the chrome inspector. Any suggestions?
Brandon
https://community.esri.com/groups/web-appbuilder-custom-themes?sr=search&searchId=4671319c-5238-4b92...
KellyHutchins
Esri Frequent Contributor
You can do it with the following JavaScript
        var popup = map.infoWindow;
          on(popup, "maximize", function(){
            popup.resize(300,300);
You may also be able to get it to work with css but it might be a bit fiddly due to the different sections of the popup (sizer, title etc).
KellyHutchins
BrandonPrice
Anyway to do this with css?
KellyHutchins
Probably but it'll take some playing around with the css this is something that is much simpler with JavaScript.
BrandonPrice
Thanks. I will try that js way.
