Hi all,
I am creating a survey with a large number of records using multiple dependent cascading selects and an external choices tab. When I save the excel and Survey123 creates the itemsets.csv file, it adds .0 to the end of some of the values as they are integers. However I have stored them in the excel spreadsheet as type "text", and have added esriFieldTypeString to the survey tab, so I would not expect this.
In the survey tab:
in the external_choices tab:
in the itemsets.csv file:
in the survey:
This is casuing me issues when I try and use pulldata to automatically populate other fieilds from an external csv based on the results of this field, as it does not expect the .0 and so the lookup fails.
If I manually find and replace .0" for " using notepad++ in itemsets.csv then everything works ok. This is not an acceptable solution for the client however.
Is there a way to prevent this from happening?
Regards,
Marc
Hi Marc,
This is a known issue with external selects using numeric choices in the itemsets.csv, it is a limitation of current pyxform implementation. We have an open issue in our backlog to which I have added your comments.
As a workaround for your pulldata() funciton, you could add an additional field with integer type and use a calculate to cast the select_one answer as an integer. You can then make the select_one question have an esri field type of null or make it hidden, and also do the same for the integer question, unless you want that store either or both of those in the feature service. The pulldata() function would then point at the integer answer.
Regards,
Phil.
