Hi!
I was able to build and run the viewshed example - ok.
(arcgis-runtime-samples-qt-master/ArcGISRuntimeSDKQt_CppSamples/Analysis/ViewshedLocation)
But i am not able to move that code into our application. (Linux: openSuse 42.3; Qt5.10, gcc 4.8.5)
As result no viewshed is visible, no errorMessage - just not visible.
Does someone knows common pitfalls?
Which kind of log messages can be enabled?
Which tools can be helpful?
Any help would be appreciated.
Thx in advance
Solved! Go to Solution.
Hi!
In the meantime we recognized the problem:
Hi Norbert- did you find the solution? If it works in the sample that you built on your system, it indicates your system should support everything you need. As for common pitfalls, I often remember to add the viewshed to the analysis overlay, but forget to add that analysis overlay to the actual scene. I also find that I sometimes need to change the heading/pitch/etc for it to display as I desire.
Hi!
