Can you physically edit a point cloud?
1606
01-03-2018 04:50 AM
deleted-user-Y1HBxau-94fD
Can I select points and delete them and can you physically save off a point cloud that just consists of the ground. I know I can classify the points and create a definition query but can I export those points out as a seperate .las dataset? #lidar
Tags (1)
DanPatterson_Retired
JakeSkinner
Esri Esteemed Contributor
Hi Dave,
I believe you can do this using the LAS Dataset Profile View tool:
Editing LAS point classification—Help | ArcGIS Desktop
Thanks Guys, I will test these suggestions out when I have second. I'll make sure to let you know if they work!
