AnsweredAssumed Answered
ArcServer GP Task can only write to local drive
Question asked by devonc1301 on Dec 28, 2017
This GP Task is being invoked by the "submitJob" url in the ArcGIS REST API, and parameters are passed in via a query string. It's output is a sql file that writes to the output path provided as input. Whenever that path is on the C:// drive of the server it succeeds but whenever I point it to another drive it fails with the error:
IOError: [Errno 2] No such file or directory:
I have the connections set up in File Explorer/ArcCatalog and the script succeeds when run as a Script Tool from ArcCatalog, but it seems when being run as a GP task and invoked with a url it no longer recognizes the drive connections. I've tried with both a UNC and [LETTER]: for the drive.
I'm using ArcServer 10.1.
Outcomes
