Survey123 Connect publish dialog data link doesn't work
663
12-24-2017 11:55 PM
AnastasiaNaymushina
New Contributor III
I've noticed that the link to the survey service doesn't open the service page properly. The page displays Token required message and doesn't show service info. Is it ok?
JohnathanHasthorpe
Hi Annastaysia
The Connect link will take you to the form item online. You would be prompted to sign into ArcGIS Online to access it (if it is secured) and then you should be able to follow the links to the layer, and then feature service url:
As long as you are signed into to ArcGIS online, you should not be prompted for a token.
John
AnastasiaNaymushina
New Contributor III
I'm signed in to ArcGIS Online. So, that means this is a bug?
JohnathanHasthorpe
Can you confirm that there is a token at the end of the url you are using to access the service, e.g
//services5.arcgis.com/jMCHJcLe13FaKCFB/arcgis/rest/services/service_a596f962b6b94c07b0ffc58430c1bd29/FeatureServer?token=HIkrzVFWfjdk............
AnastasiaNaymushina
New Contributor III
