How to Select Graphics From Graphics Layer Inside a Clicked Circle
3219
12-20-2017 02:47 PM
BehrouzHosseini
Can you please take a look at This Demo and let me know how I can get geometry of selected Graphics which are inside the clicked circle extent
var map;
var baseCircle;
require([
  "esri/map", "esri/layers/FeatureLayer", "esri/layers/GraphicsLayer",
  "esri/tasks/query", "esri/geometry/Circle", "esri/SpatialReference", "esri/geometry/Point",
  "esri/graphic", "esri/symbols/SimpleMarkerSymbol",
  "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
  "esri/config", "esri/Color", "dojo/dom", "dojo/domReady!"
], function(
  Map, FeatureLayer,
  GraphicsLayer,
  Query, Circle, SpatialReference, Point,
  Graphic, SimpleMarkerSymbol,
  SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer,
  esriConfig, Color, dom
  esriConfig.defaults.io.proxyUrl = "/proxy/";
  map = new Map("mapDiv", {
    basemap: "streets",
    center: [-88.158805, 41.786075],
    zoom: 14,
    slider: false
  var pointGLayer = new GraphicsLayer();
  //pointGLayer.setRenderer(pointRenderer);
  map.addLayer(pointGLayer);
  var data = [
    [-88.13198711899997, 41.79304797900005],
    [-88.13559945399999, 41.79100138000007],
    [-88.13565587999994, 41.79234125500005],
    [-88.13645828899996, 41.79017487800007],
    [-88.13801440299994, 41.790968630000066],
    [-88.13797007499994, 41.791996288000064],
    [-88.13798992699998, 41.79258648200005],
    [-88.12837351899998, 41.79370832500007]
  var symbol = new SimpleMarkerSymbol(
    SimpleMarkerSymbol.STYLE_CIRCLE,
    12,
    new SimpleLineSymbol(
      SimpleLineSymbol.STYLE_NULL,
      new Color([247, 34, 101, 0.9]),
    new Color([207, 34, 171, 0.5])
  for (i = 0; i < data.length; i++) {
    var pt = new Point(data[i][0], data[i][1], new SpatialReference({
      wkid: 4326
    var graphic = new Graphic(pt, symbol);
    pointGLayer.add(graphic);
    12,
  var circleSymb = new SimpleFillSymbol(
    SimpleFillSymbol.STYLE_NULL,
      SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
      new Color([105, 105, 105]),
    ), new Color([255, 255, 0, 0.25])
  var circle;
  map.on("click", function(evt) {
    baseCircle = evt.mapPoint;
    console.log(baseCircle);
    circle = new Circle({
      center: evt.mapPoint,
      geodesic: true,
      radius: 1000,
      radiusUnit: "esriMeters"
    map.graphics.clear();
    var graphic = new Graphic(circle, circleSymb);
    map.graphics.add(graphic);
    var query = new Query();
    query.geometry = circle.getExtent();
RobertScheitlin__GISP
Sure just add an else to the if:
    var gras = pointGLayer.graphics;
    gras.map(function(gra){
      if(circle.contains(gra.geometry)){
         console.info("graphic is inside circle");
      }else{
         console.info("graphic not inside circle");
Bengi,
  So you want to query the graphics from the pointGLayer that intersect the circle? If so then you do not use a query because that requires a url or at least a FeatureLayer make from a FeatureCollection. In your case only working with a GraphicsLayer you need to loop through the Graphics in the GraphicsLayer  and use the circle.contains method on each of the graphics.geometry.
BehrouzHosseini
Thanks a lots Robert is there any way also to get Graphics which are not in the Circle?
      }else{
