python loop - saving output
6136
12-17-2017 12:24 PM
by Anonymous User
Not applicable
The script is intended to subtract the loop variable from a raster and save the raster using an appropriate name.
I tried quite a few work-arounds, but all methods seem the hit a wall. The attached image shows that the same simple tool in modelbuilde casts the same error.
Anyone that made something similar?
Via this simple python loop:
import arcpy
stepper = 5
for stepper in range (20):
      name="AFVdtm"+str(stepper)
      name= arcpy.sa.Minus("DTM_frostkærLocal.tif",stepper)
      stepper += stepper
      rod = "c:/testmappe/"
      name=name
      eft=".tif"
      sti=rod+name+eft
      name.save(sti)
File "<string>", line 10, in <module>
File "c:\program files\arcgis 2.0\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4331, in Plus
in_raster_or_constant2)
File "c:\program files\arcgis 2.0\pro\Resources\arcpy\arcpy\sa\Utils.py", line 53, in swapper
result = wrapper(*args, **kwargs)
File "c:\program files\arcgis 2.0\pro\Resources\arcpy\arcpy\sa\Functions.py", line 4328, in Wrapper
["Plus", in_raster_or_constant1, in_raster_or_constant2])
RuntimeError: ERROR 000732: Input Raster: Dataset c:/testmappe/ does not exist or is not supported
I have tried using relative and absolute paths, which doesn't change anything in the error.
 Running it like:
import arcpy
stepper = 5
for stepper in range (20😞
    stepper += stepper
    name.save("c:/testmappe/%name%.tif")
Produces the intended output, but continously overwrites it
Tags (1)
DanPatterson_Retired
Code formatting the basics++
Because it looks off.. and your paths don't look correct to begin with.  I would throw some print statements in to get an idea of what the actual inputs and outputs look like
by Anonymous User
Not applicable
I just updated it, does that help?
Please don't pay attention to indentation, it is obviuosly somethings that happens when pasting.
When using the modelbuilder solution I see that Minus/Raster Calculator interpretes the output of the For loop as a string  Jeez, ESRI.
I edit it to int(%Vakue%) which solves the calculation-part of the problem. Not the saving-part.
name is still wrong... try to create one using a base name..
outName = "thisfile"
then you can append to that file with your stepper
sti = "/".join([rod, outname+str(stepper), eft])
