I would like to make my show x,y script I got from ArcGIS API for JavaScript Sandbox media responsive. I want it centered at all times. I also want the x,y raised to 50px when the screen size is less than 768px. I have not been able to do this. This is what I have:
CSS:
@media screen and (max-width: 768px) {
#xy {
position: absolute;
l eft:5px !important;
bottom: 70px;
HTML:
<div id="xy">
<i>Lat/Long: </i><span id="coordInfo"></span> <i>(DD)</i>
</div>
Script:
function showCoordinates(evt) {
//the map is in web mercator but display coordinates in geographic (lat, long)
var mp = webMercatorUtils.webMercatorToGeographic(evt.mapPoint);
//display mouse coordinates
dom.byId("coordInfo").innerHTML = mp.x.toFixed(3) + ", " + mp.y.toFixed(3);
// The application is ready
topic.subscribe("tpl-ready", function(){
app.map.on("mouse-move", showCoordinates);
app.map.on("mouse-drag", showCoordinates);
Any suggestions appreciated.
Brandon
Solved! Go to Solution.
Andy beat me to it but here is another sample based on what you are trying to do:
<!DOCTYPE html>
<html>
<head>
<title>Create Map Display Mouse Coordinates</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.22/esri/css/esri.css">
<style>
html, body, #map{
width:100%;
height:100%;
margin:0;
padding:0;
#xy {
position:absolute;
left:15px;
bottom:5px;
color:#000;
z-index:50;
#xy {
position: absolute;
left:5px !important;
bottom: 70px;
color:#000;
z-index:50;
</style>
<script src="https://js.arcgis.com/3.22/"></script>
<script>
var map;
require([
"esri/map", "esri/geometry/webMercatorUtils", "dojo/dom",
"dojo/domReady!"
], function(
Map, webMercatorUtils, dom
map = new Map("map", {
basemap: "streets",
center: [-47.109, 14.945],
zoom: 2
map.on("load", function() {
//after map loads, connect to listen to mouse move & drag events
map.on("mouse-move, mouse-drag", showCoordinates);
</script>
</head>
<body>
<div id="map">
<div id="xy">
</div>
</div>
</body>
</html>
Here's a rough sample that might be similar to what you want: JS Bin - Collaborative JavaScript Debugging
<!DOCTYPE html>
<html>
<head>
<style>
html, body, #map{
width:100%;
height:100%;
margin:0;
padding:0;
#xy {
position:absolute;
left:15px;
bottom:5px;
color:#000;
z-index:50;
#xy {
position: absolute;
bottom: 70px;
color:#000;
z-index:50;
</style>
<script>
var map;
require([
"dojo/domReady!"
], function(
basemap: "streets",
zoom: 2
</script>
</head>
<body>
<div id="map">
<div id="xy">
</div>
</div>
</body>
</html>
Thanks for the example. I am not sure what part of mine was incorrect. Something with the css was off though. I was able to get it to work using the css provided above.
-Brandon
I figured out what the problem was. I doubled up on my css. I had css in my html body I forgot to delete after I added css to the style part of my html.
