Failed to publish web layer
1146
12-12-2017 05:10 AM
huei_yicheng
Hi all
I'm try to publish a web feature layer to my organization's portal.  The SharingJobLog show Successfully staged service, Publishing web layer failed (AGO), Publishing tool execution failed. the layer i want to publish has about 1054084 polygons. The setting is as below. I try to publish a layer about 20000 polygons, and it is success in publish, so what could be the problem make the work fail? is that too many polygons in this layer?
PanagiotisPapadopoulos
huei_yicheng
thanks, but i'm using ArcGIS pro, so is there also a MXD problem?
No, I sent this because the workaround may fit also in your case (use Gloabl ID and split the table  Split the table to 750,000 records)
